The picture is blinking on and off
It will turn on but the picture will not stay on
No picture with sound tv turns off. Mitsubishi model WD65837
are any lights lit up when it shuts down? If so which light what color is it and is it blinking or a just stays lit without blinking?
Apr 05, 2013 | Mitsubishi WD 65837 TV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
We have a Mitsubishi tv Model WS48311 purchased in 2003. Recently the picture will blink off and then return on in rapid succession. The sound stays on when the picture is blinking. We hit the ?menu button...
You have bad switches on the front panel. Press them 50+ times to release them. Failing this you will have to replace them. You can disconnect the front panel to confirm this.
Jun 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Oct 11, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Nov 26, 2008 | Panasonic TH-42PHW5 Television
Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Jun 28, 2008 | Sony KP-53HS10 TV
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
