Question about Samsung CLX-6200FX Printer
Adc slope error Samsung CLX 6200
My printer is saying ADC slope error power cycle. What do I do?
4 Suggested Answers
  • 406 Answers
SOURCE: printer arrived to day on first system
You need to change the fuser unit.
Posted on Sep 01, 2009
  • 13 Answers
SOURCE: Samsung clp-610 has an error code of
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Posted on Nov 24, 2009
Ezrahite
  • 2632 Answers
SOURCE: There is an "ADC
Welcome to Fixya. ADC Slope Error Cycle Power means that The temperature slope for ADC (Analog to DigitalConverter) detects the value out of the normal range. This is a Service Call Error of CLP-610ND
Solution: This problem can be fixed by just Power Cycle. However, if the problem persists, contact the service representatives.
You can also refer to the user manual below.
Samsung CLP-610ND User Manual
Thanks for using Fixya.
Posted on May 19, 2011
Adc sensor error
adc sensor error / error 092-651 .....docu print cp205....please help me...i cant find the solution....
Jan 21, 2013 | Xerox FUJI DOCUPRINT CP205 COLOR LASER...
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
Samsung clp610nd ADC Power Slope
Nov 12, 2009 | Samsung CLP-610ND + Demo Laser Printer
My docucolor 12 say 9-612 error in the adjustment
9-612 TRC RADC Out Of Range RAP Initial Actions Clean the ADC Sensor. Clean the IBT Belt. Check that the P/J139 on the ADC Sensor PWB, IBT connector J702A, J702B and P/J416A on the IOT Drive PWB are firmly connected. Videc
siriusdigitalbox@gmail.com
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
Samsung CLX-6200FX Printer Logo
99 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
