Question about Samsung HL-T6187S Television
Samsung HL-T6187S SOUND DROPPING TO 0? By itself
I have a DLP HL-T6187S Samsung that is nearly constantly displaying the volume bar AND dropping the volume to 0 if it isn't already. When the volume bar is displayed no other functions work, including powering off. I thought I read of similar problem and that it related to the side buttons , which I never use, so I attempted that suggested solution and disconnected the buttons from rest of board. Unfortunately this also disabled the remote, not just the side buttons. It is very random in occurence, and it is NOT a stray signal as the remote makes LEDs light up front but no lights when it randomly drops volume to 0.
  • 1 more comment
  • Hatless Feb 22, 2012
    Now the volume bar (at 0) is on constantly and I can not change anything with remote or side buttons mounted on the TV itself.
  • Hatless Mar 13, 2012
    It went away for a while and was all normal. Then it came back. I took it apart and did what was suggested with removing the side cabinet buttons. This time I took it a little more apart (just the exterior screws) and was able to get to the small connector for JUST the side buttons. I disconnected that small connector and my TV is working fine. It is too bad this seems to be a typical Samsung problem from all I found online about it.
  • Hatless Mar 14, 2012
    Thanks for reply. Why would it be the button itself? Why a little here and there with large time lapses and then never for a long time and then constant for a while? I never used those buttons. And now that I removed them, all is well. Thanks goes out to whomever posted that solution on another Samsung set with same symptoms.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Posted on Mar 13, 2012
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
SOURCE: Samsung LE32R87BD-Turns itself on
Hey Devaman, like you I have just upgraded the software and disabled all of the timers, but most importantly I have disabled the "update whilst on stanby" option from the SETUP menu. It now seems to behave...
One more comment, I was very dishappointed by Samsung lack of interest, they never bothered to reply to my email, which I think is extremely rude... but then, am I surprised? :¬)
Peace
Posted on Apr 10, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
SOURCE: samsung model LNS4051DX/XAA won't turn on, just clicks
THE PROBLEM IS Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Posted on Jan 01, 2009
SOURCE: Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
My samsung does the samething. TV is 3 yrs old. Repair guy said, it needs a new computer board. Said, that about 75% can be repaired if you can see what the problems is on the board. But the others show no sign so has to replace the whole board at $175.00 for the board and total cost around $300.00.
Posted on Aug 20, 2010
Why is the sound limited on my Samsung HL-S5688W DLP?
Might be in Hotel mode, audio limited condition. Enter it service mode and make it to normal mode. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 14, 2017 | Samsung Televison & Video
HL-t6187s control problems
Check with Samsung, your model falls under a class action settlement related to power supply issues that your TV may be experiencing. Here is a link to more information about this settlement.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Jul 16, 2012 | Samsung HL-T6187S Television
Hl-t6187s looking for fan #1
you can get replacement fans from www.tvrepairworld.com and also free tech assistance for proper diagnosis
Mar 16, 2012 | Samsung HLT6187SAX 61" DLP HDTV
I have a SAMSUM HL-T6187SA DLP LED 1080P. The problems I see are a Green Tint and the RED(s) display as Blue(ish). John
It sound likes the problem of your unit is the light engine. This is very common problem on Samsung DLP TV's and tons of complaint regarding on the picture quality. If you search "Samsung DLP law suit" you will find various comment regarding on the issue.
This part is an expensive one and I would advice you to call Samsung service department (1-800-726-7864) to let it diagnose by their Technician and see if they would cover the parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 25, 2011 | Samsung HL-T6187S Television
I have a HDTV DLP TV HLT6187SAX/XAA I have problem with the color, now all in green, red and yellow. the blue was gone. I want to know is that the problem from the lamp or the bulb?
He is talking about the HLT6187SAX/XAA which is an LED model not the HL-T6187S model which has a lamp unless he gave the wrong model number in the original post.
Jan 18, 2011 | Samsung HLT6187SAX 61" DLP HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 42" Volume Problem
you might want to get a tech to come and check the service menu and see if some of the audio settings have moved or are miss adjusted as per the mfg. settings
Jun 05, 2008 | Samsung DLP HL-P5663W 56" TV
SET DOES NOT COME ON
never fool with led or indicator lamps.... its telling you your power is dropping out somewhere ...most likely a regulator on the PS Board.
Sep 02, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-T6187S Television Logo
208 people viewed this question
Jerry Greenberg
Jerry Greenberg
