Question about HP Computers & Internet
1995 winstar electric door locks quit working how do you find relay
  • 1,205 Answers
Hi there
Would you be so kind as to explain further
kolla
Posted on Feb 21, 2012
2003 Cadillac STS door and truck lock quit working
I checked all the fuses and relays and all are in good shape???????
Did you check the correct one's ,that's the question ? And did you use a voltmeter or test light to check across the correct fuse's ? And how did you check the relay's ????? Videos on youtube on how to test a relay ! And using a wiring diagram or power flow diagram that shows all componets of the none working systems ., Plus you need to know how the thing's work . Data communication network is involved in the working of these thing's , Data messages from module to module !
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Just looking at fuse's and relay's isn't enough ! Hooking up a factory scan tool an checking for DTC'S - diagnostic trouble codes in all the vehicle control modules is always the first step . Which fuse boxes did you check ? Do you know there is a fuse box under the back seat ?
Fuse Block - Rear
Left rear of the passenger compartment, under the rear seat !
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door, but the rear integration module (RIM), which is the master control for the door lock system, determines when the lock functions are permitted. The RIM receives and examines the requested lock function from the individual door modules, or from the remote function actuator (RFA) via the class 2 serial data circuit. The RIM also examines the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. If the RIM determines that a lock or unlock function is permitted, it sends a class 2 message back to the individual door modules commanding them to perform that Lock or Unlock function.
Your best bet , take it to the dealer !
Jun 06, 2017 | 2003 Cadillac Seville STS
95 Camry Electric Door Locks Won't Work
It could still be the relay, if the solenoid is working but the contacts are faulty. There are also several other places in the circuit which could cause this. Follow the diagnostics from p90 on, here
http://www.turboninjas.com/camry/be.pdf
Jun 25, 2012 | 1995 Toyota Camry
1995 Jeep Grans Cherokee electric door locks not working when I hit the button they won't work. they make some sort of noise but they don't lock or unlock. only seems to lock the back hatch but...
Well, it is hard to say for sure without some electrical testing. It could be that you need to buy a whole bunch of door lock actuators - especially if you started losing one door lock at a time. If all of the door locks started acting up all at the same time, there is most likely high resistance in one of the door lock main power circuits - like the one that comes from the ignition switch or from the keyless entry module (if equipped).
Then on the other hand, if they LOCK OK, but do not want to UNLOCK (or visa-versa) there could be worn or burned contacts in either the lock relay or the unlock relay (or possibly even BOTH).
Again, some electrical testing should be done to pinpoint the actual cause of the problem before going out and spending a bunch of money on parts.
Oct 05, 2011 | 1995 Jeep Grand Cherokee
DOOR LOCKS JUST QUIT WORKING WONDERING IF IT IS A FUSE
I would check fuses first. If fuses are good you may need to check relay or take off door panel check continuity to switch with a volt meter, let me know what you find.
Feb 06, 2010 | 1995 Chevrolet Tahoe
Power door lock switch won't work
i would look at all of my plugs
Aug 10, 2009 | 2002 Ford Explorer
2001 Chevrolet Impala Door Locks Suddenly Quit Working
Passenger side of the fender under the hood - check the fuse relay box - about $12.00 a piece - they do go bad from time to time.
exchange the power lock relay with another one and test the locks.
then put the relay back and go to the autostore.
Aug 07, 2009 | 2005 Chevrolet Impala
1995 Volvo 850 Electric Door Looks do not Work
IT SOUNDS LIKE THE REMOTE BATTERY IS BAD AND IT MUST HAVE 3 VOLTS AND AFTER REPLACING IT CYCLE KEY 5 TIMES ON AND OFF THEN PUSH EITHER BUTTON AND IT SHOULD ACCEPT THE PROGRAMMING TRY THIS FIRST AND TELL ME IFIT DOES NOT WORK
Apr 01, 2009 | 1995 Volvo 850
Location of a door lock relay 1995 ford aerostar
its in the lock actuator where the door closes
Mar 08, 2009 | 1995 Ford Aerostar
1994 buick regal-passenger door lock will not operate with electr
first check or replace the relays in the fuse panel under the dash for those two circuits and see if that fixes it
Feb 23, 2009 | 1995 Buick Regal
2005 town & country electric door locks quit working
the door locks are controlled by the body computer and one of the switches may be bad. When you pull the fuse you are clearing the computer codes and the locks work fine until that switch acts up. once the computer sets a code for a shorted or stuck switch all switch inputs are ignored until you pull the fuse and reset everything. Could also be a bad wire to the switch or a bad computer.
Jan 16, 2009 | 2005 Chrysler Town & Country
Computers & Internet Logo
14 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
