Question about Eureka 4718AVZ LightForce 300 Bagless Upright Vacuum
My vaccum is making a loud noise - Eureka 4718AVZ LightForce 300 Bagless Upright Vacuum
Loud noise when running
It may be a broken fan. You will have to disassemble it to find out.
Jan 16, 2014 | Halo UVST Bagged Upright Vacuum
Our dyson vaccum is making a loud noise when we vaccum. (other than the normal loud noise) it is a dyson 23 plus..
Sorry to hear you're having trouble with your DC23 Plus. You might find it helpful to wash the pre-motor filter, and to check the cleaner for blockages. You can find a step-by-step guide showing how to do this in the Support section of our website:
http://www.dyson.com/support/help.asp?article=1276&product=DC23-PLUS
You should find that this resolves the issue. However, if you've tried this and you're still concerned about the noise, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON. We can run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 25, 2011 | Dyson Vacuums
MY HOOVER VACCUM MODEL #U5185-900 IS MAKING A LOUD VIBRATING NOISE AND I CANT FIX IT, IT STILL PICKS UP STUFF BUT THE NOISE IS UNBEARABLE. cAN YOU HELP ME
t could be 1 of 3 things:
1. The belt2_bing.gif that drives the beater bar.
2. An impeller that has a broken wing or 2, throwing it off balance.
3. Or, the bearings in the motor are going out.
Hope this helps,
Jim
Please Rate this Solution: THANKS
Dec 01, 2009 | Vacuums
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
My Bissel Vaccum cleaner is making strange noise!!
call the 1-800 number on the back
Jun 11, 2009 | Vacuums
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Extremely loud
Mine started making a lot of noise and my husband noticed the brushroll was slightly bent. I have no idea how this happened, but I noticed several people online were having the same problem. I ordered a new brushroll and popped it in and solved the problem. The noise before I did this was horrible! It is now back to normal.
May 23, 2008 | Hoover U5507900 Elite Rewind Bagless...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Eureka 4718AVZ LightForce 300 Bagless Upright Vacuum Logo
43 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
