Question about Toshiba Computers & Internet
How can i connect my toshiba p100 to a samsung hdtv
When i plug my hd converter into to my p100 mode not supported comes up n my samsung tv
Maui Walt
SOURCE: hook up problem
change the source of the input using the remote's source button
Posted on Dec 11, 2007
headstrong
  • 233 Answers
SOURCE: not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Posted on Dec 29, 2007
cpenzes
  • 1102 Answers
SOURCE: HDTV as monitor via VGA
Could be that it's to old to support
you can try to put new driver on sounds like it's an older version
Posted on Jan 12, 2009
SOURCE: blank screen saying (mode not supported )
I had this today on my Samsung 46" TV while connected to a DVD Receiver (Panasonic).
I don't know why it happened in the first place but the DVD was trying to output a format that the TV could not produce.
Holding the Cancel button on the Panasonic Remote for a few seconds fixed this.
Posted on Jan 19, 2009
SOURCE: Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Posted on Jan 22, 2009
What is the best converter box to use with toshiba regza 42hl67 flat screen tv?
As far as I can make out, this Toshiba model is made for the US market so doesn't actually have a freeview tuner. It will only receive satellite and cable HD signals and local US TV, all of which has to be bought. You need to get something like an August DVB400 - HD Freeview Set Top Box -Digital PVR Tuner with USB TV Recording, eBay would be best I think, where they are sold for under £30.00. The tuner packed up on my 32" Regza so I bought one of these and it works fine. Plus you can record to a USB stick if you don't want to miss a programme. Hope this helps ......BS
Feb 22, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Can you connect a hd converter to a Toshiba cx 32 g60 tv
there isn't much point in connecting an hd converter the toshiba cx32g60. the tv can only support an sd signal (composite video or ntsc analog). however, many hd set-top boxes (dvd players, cable and satellite) have composite outputs. these can be connected to your tv. blu-ray videos can't be watched with this tv. (the hdcp (high definition copy protection) can't be sent through most converters.)
if you want to watch ota programming , the cheapest option would be to find an sd digital-to-analog converter. these were the ones sold when most stations switched to digital tuners. some are being sold off as people replace their old analog sets. there are some hd tuner boxes, like this one: http://www.solidsignal.com/pview.asp?mc=03&p=3500stb&d=iview-hd-dvr-receiverconverter-box-for-tv-antenna-qam-%283500stb%29&c=digital%20converter%20boxes&sku= , that have composite video output which will connect to the cx32g60.
i hope this helps.
cindy wells
(if you tried an hdmi to component video converter followed by a component to composite video converter, the signal may degrade excessively.)
Jan 22, 2015 | Toshiba Televison & Video
No hdmi port
u can buy USB to HDMI converter cable...just check the manual for ur TV if it supports it also can try AV to HDMI converter cable
Feb 13, 2012 | Toshiba Satellite Computers & Internet
I have my tv in pc mode. how do i get audio to work \
You must plug speakers into the the computer because the sound comes from the pc I have a pc which I plug into my hd tv so that should work
Jan 03, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Hook up problem
And your problem is ...?
Aug 24, 2008 | Televison & Video
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Computers & Internet Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
