York Diamond 90 furnace blows cold air
Furnace lights and works, then cycles the gas off, fan continues to blow, red led flash 4 times through 14 cycles then the furnace lights again, this will occur 1 or multiple times before it finally tries to light the ignitor starts and requests gas and nothing happens. Once the furnace doesn't light the led goes solid red and the fan continues to blow until furnace is reset. Control module says replace controller when light is solid. I just don't know if the 4 led's flashing between cycles is normal White-Rodges 50A50-241 controller
  • David Feb 25, 2012
    It turned out to be a bad controller board. Replaced and furnace is working fine. Thanks for all the help.
  • 41 Answers
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Posted on Feb 23, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: INSTALLATION MANUAL FOR PV9C YORK FURNACE
i think it is a single stage furnace, all wiring are the same. use R and W, no other wires needed if you have no aircon. connect C if you want thermostat uses AC power from furnace.
Posted on Nov 20, 2009
  • 232 Answers
SOURCE: our york furnace is not Lighting
you may have a bad ignitor, that would be the simplest thing, but without more info thats all i got
Posted on Nov 25, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 furnace (propane conversion),
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Posted on Dec 28, 2009
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
12 year old HE York diamond 90 furnace burners ignite for a few seconds but won't remain lit. Hot surface igniter then glows and burners again light momentarily. Cycle repeats several times before blo
The flame sensor can still be faulty, replacing that is the cheapest. Other issues could be a faulty control board (if available), a faulty gas valve, thermostat lossing call, or a safety/pressure switch problem. There are alot of variables and it really helps to have a meter to check voltage and continuity through-out the system.
Dec 07, 2013 | Heating & Cooling
Luxaire by York Furnace,Model# G8T10012UHB11A,8 Red LED Flashes = Ignition lockout due to recycles,Has flame for a few seconds then goes off; does it around three times,Fan is working; blowing cold air
It sounds like you have a dirty or bad Flame Sensor. They sometimes get a white coating on them. It's not detecting a flame so it shuts off. Sometimes you can clean them and they will work.
Nov 06, 2012 | Coleman Heating & Cooling
My central AC is a York Diamond 80 (also my furnace). Thermostat set on Cool, isn't cooling. and when i shut thermostat off, it continues to blow air. red light flashing inside unit code = Limit switch...
One of the limit switch in the furnace is tripped or went bad....
Try to find all of the reset switches and push the little red button on the top to reset them...
If that don't work you will need to take an electric meter and test each switch to see which one is bad...
heatman101
Aug 23, 2010 | Heating & Cooling
The furnace attempt to light, you can see the
The flame sensor is not sensing the flame. Google "flame sensor"
May be an adjustment or control board problem.
Dec 08, 2009 | York Furnace Draft Inducer Blower Fasco #...
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
Problems with Furnace
On is just the blower fan nothing else, check to see if there is a reset button in the tstat or tripped over load inside the furnace, inside the furance is some safetys, you will see wires runing from each other and finaly to the gas valve, push each untill one of them clicks,then your furnace should start back working, but I would still have someone come out and check why it tripped, because as I said it is a safety, and when it tripps it is for a reason.
Oct 19, 2008 | Heating & Cooling
Heating & Cooling Logo
766 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
