For idle issues and
problem troubleshooting,go through the help links provided below :-----
van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html --------- http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html ---------- http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html ----------- http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html ------------ http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html ---------- http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html --------- http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html ----------- ---------- http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html ------------ http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html ------ http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html --------- This will help. Thanks.
will not idle when cold?
runs lean and idles rough?
Engine stumbles coming off idle when warm?
Erratic idle on car?
Low idle when cold out side?
Idle Air Control (IAC)
Valve Replacing?
Replace
Idle air control valve?
Test
Idle Air Control (IAC) Valve?
Idle
Air Control (IAC) Valve operation?
Engine quits at idle?
Car overheats and Air blows
hot at idle?
While stop engine idles
like cylinder missing?
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
SOURCE: How to tighten side mirror. 1996 dodge ram 1500 manual mirrors
take door pannal off there should be 3 bolts in the inside of the door where mirror sits unless its the reflection peace where you have to just get a new mirror
SOURCE: 98 dodge ram 1500 rear axle, setting the backlash
there are adjusters on each side of carrier. do most of adjusting from driver side.need about 8 thou of backlash
SOURCE: 98 dodge 1500 ram speedometer not working sender
ABS LIGHT ON AS WELL?IF SO..I WOULD LOOK AT ABS SENSOR IN REAR DIFFERENTIAL..GETS SPEED SIGNAL FROM THIS SENSOR AS WELL..USES ONE IN TRANS FOR TRANS SHIFTING
SOURCE: anti theft is on truck won't start how do you reset
you cant "reset it". if you could than anyone could steat your truck. take it to the dealer or other well equipped shop that works on your truck.
