Question about Sony KDL-46VL160 46 in. HDTV TV
Sony KDL-46VL160 Half of screen is Black or dark
I have a Sony KDL-46VL160 and it suddenley is showing a portion of the screen Black or dark
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500 40" lcd hdtv
I risk getting a bad rating from you, but it sounds as though you have a bad LCD panel. I have seen sections of the panels fair, usually caused by a separation of the ribbons connecting to the panel itself or a bad TCON board (the board that addresses the pixels. It is part of the panel on Sony TV's). Your best bet is to contact Sony customer service at 800-222-SONY to see if they will work out some kind of accommodation on the repair, like possibly covering the parts or splitting the repair costs with you. I hope I have provided you with good information and you do not rate me poorly for your bad news.
Posted on Nov 10, 2008
welcomejee
  • 10594 Answers
SOURCE: KDL-40S2000 horizontal black lines
Seems T-Con board mounted at top center at rear of LCD Panel is bad.
Local TV tech will fix TV by replacing T-Con board.
Thanks.
Posted on Aug 30, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 49 Answers
SOURCE: sony 46 KDL 46S2000 screen went black and the
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
tvservice306
  • 458 Answers
SOURCE: "Plaid" screen on sony Bravia
go sony web
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
Posted on Mar 13, 2010
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Why is the picture on my Sony KDL-46VL160 good on the left, dark in the center and distorted with slow refresh to the right?
Back-light problem. Contact the authorized service center for Sony.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 27, 2014 | Sony KDL-46VL160 46 in. HDTV TV
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
RIGHT SIDE IS DARK
Check and replace the back-light inverter. This is a back-light problem.
Gopakumar Gopalan Google
Feb 23, 2014 | Sony KDL-46VL160 46 in. HDTV TV
My sony lcd KDL-26EX420 is showing bar in half screen and pic upside down
screen driver has failed at some point. could be the out put side or the input side. try cleaning the connection at both ends see if it comes back right again. if not you may need a new one.
Nov 27, 2012 | Sony BRAVIA KDL-46V3000 Television
Kdl-46vl160 no picture but back light working
If the screen lights up a very dark blue almost black then the Tcon would be suspect. You can get the replacement Tcon from www.tvrepairworld.com
Nov 07, 2012 | Televison & Video
Dark partial Screen
Morning to you
If you have not looked at the troubleshooting pages in the manual, then the next best thing is to make sure that all cables are where they should be. Mos important to check the scart connecons.
hope this works for you as it has doneforme.
All thebest
kolbrun
Feb 21, 2012 | Sony KDL-46VL160 46 in. HDTV TV
Large area at top of the screen is not bright , constant, appears like atop filament of a bulb is blown?
chances are you have a bad inverter board. It can cause half the screen to be dark if a portion of it is bad. There is also the chance that a phosphor lamp could be bad in the panel but usually that would cause the set to shut down.
Oct 22, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL-46VL160 46 in. HDTV TV Logo
1,410 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
