Question about Car Audio & Video
No sound from 2003 hyundai sonata speakers
Just got this 2003 Hyundai Sonata from a dealer and they stated the radio didn't work. Since I got it the radio itself has power, switches channels and even stays correct on time but there is absolutely no sound coming out of any of the speakers. I checked all the fuses inside the car, the wiring in the back looks correct but can't figure out what could be wrong. Anybody have any suggestions?
SOURCE: 2006 Hyundai Sonata brake light problem
there is a tsb for the brake switch in 06 sonatas. it must be adjusted or replaced by dealership. is your check engine light on, if so its probably code p0504
Posted on Jun 29, 2008
bryant329
  • 125 Answers
SOURCE: the volume or maybe the
if you happen to have a speaker available, try to test the stereo. plug in a speaker and see if it works. otherwise, i don't really like this method but, it does work... unlug your factory speaker and plug a 9v battery to the speaker, if you hear a little popping/wizzing sound, the speaker works and it's the head unit.
also, check to see if the radio has an amp. sometimes the radio will be operational, but the amp isn't and that is the problem. and the easy solution is to replace the radio with an after market of choice. factory radio's that are purchased seperately are rather expensive.
Posted on Sep 24, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Where is inertia switch for 2005 hyundai sonata?
Inertia switch is located in one of two areas, on the passenger side panels next to the toe kick by the radio. Or up under the dash. It will be a red button that you need to puch in
Posted on Feb 09, 2009
  • 69 Answers
SOURCE: Removal of Radio in 2004 Hyundai Sonata
Remove the facia plate, and remove the 4 screws that hold the radio in place. It's actually one of the simplest cars you can do.
Posted on May 27, 2009
SOURCE: Hyundai Sonata 2003 Car starts then dies immediately :(
dear friend-it appeares that you have no feul pressure,check pressure,feul filter,feul system,
Posted on Jul 21, 2009
Change the battery in my 2007 Hyundai Sonata and now my radio won't work how do I get a code and put it in?
Hyundai Tiburon Questions - how do i reprogram my lock ...
www.cargurus.com > Questions > Hyundai > Tiburon
CarGurusAug 17, 2009 - how do i reprogram my lock remote to my car? i changed my battery an ... i change my battery an now my lock an un lock buttons dont wor. ... I have aHyundai 2003 Tiburon, and the following worked for me, get in your ... The unlock codeis inside the case. ... Now my radio interior lights and clock wont work.
Hyundai replaced car battery now radio doesn t Cars ... - Fixya
www.fixya.com > ... > Cars & Trucks
Hyundai cars & trucks replaced car battery now radio doesn t questions and answers ... replaced my battery,, now key remote radio & clock does not work.. thank you ... ...car If you didn't do this before you replaced the battery, then there is another code ... I put a new battery in my 2003 sonata and now the radio doesn't work.
Jan 06, 2016 | Hyundai Cars & Trucks
I put a new battery in my 2003 sonata and now the radio doesn't work. How do I get it to work?
If the radio lights up. Reprogram radio due to power failure. Should find instructions in owners manual if it is a factory radio. Otherwise look on line for reprogram instructions.
Sep 03, 2012 | Hyundai Motor 2003 Sonata
2006 Hyundai Sonata 6 disc CD won't work!
Check with Dealer - unit may have to be reset after the power to it was interrupted during the changeover you alluded to.
Aug 06, 2017 | 2006 Hyundai Sonata
I need the radio code for a 2002 Hyundai Sonata
You need to contact a Hyundai dealer & provide your VIN# to get security code for your radio
Mar 30, 2011 | Hyundai Motor 2002 Sonata
Radio Fuse Blows Out
LOOSE EARTH IN SPEAKER WIRING
Feb 27, 2010 | 2002 Hyundai Santa Fe
Radio Reset for 2006 Hyundai Sonata
doubtful probably burnt up a component in radio thats why when jumping a vehicle u turn off all accessories so when something gets crossed it doesnt short it out usually will blow a couple of fuses
Feb 10, 2010 | 2006 Hyundai Sonata
Need diagram for wiring radio for 1997 Hyundai Sonata
1997 Hyundai Sonata Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Red
Car Radio Switched 12V+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Door
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/Whi
Mar 20, 2009 | 1997 Hyundai Sonata
04 sonata stereo wireing diagram
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Jan 01, 2009 | 2007 Hyundai Sonata Limited Sedan
Lost car radio code
i need a radio code for 1995 Hyundai Sonata radio v#kKMHCF24F6SU446697 thanks
Aug 15, 2008 | 1999 Hyundai Sonata
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
