Question about Yamaha Wave Runner GP 800
Line that connects to the water nozzle outlet on a Yamaha Waverunner
What is the rubber line that connects to the water outlet nozzle for?
3 Suggested Answers
  • 90 Answers
SOURCE: 1996 yamaha waverunner is overheating. has a good
most common problem with overheating when you have good water flow is the thermostat is stuck open replace it.
Posted on May 31, 2011
ruskinbikesh
  • 180 Answers
SOURCE: my 1992 yamaha waverunner iii 650 is taking on
I know this sounds obvious, but make sure the plugs are screwed in.
usually 2 of them at the back of the waverunner.
i know i forgot to put them in one day and by the time i parked the truck & trailer it took on so much water the motor was half submerged.
Hurried and pull the truck back and got it out and let her drain iout the plugs, then fired it up.
anyhow, if thats not it then your hull must be cracked and leaking in, take seat off at the ramp and see if you can see where its coming from, if you don't notice anything, then its coming in through
the ports at the top of the wave runner under the steering assembley housing, those tubes are made to direct the water to the bottom, if you have an auto matic bilge pump, make sure that is working or it won't pump out the water like it is supposed to.
hope that helps
Big Al
Posted on Jun 01, 2011
I have a 1991 yamaha waverunner wr500 there is gas in the engine compartment why?
Most likely a fuel line that has failed as a result of modern fuels with high levels of methanol. Given the age of the unit I'd expect that fuel is either leaking from a cracked fuel line or directly from the carburetor because one of the rubber diaphragms has been destroyed by new fuel. PS. never leave fuel in the unit over the winter or for extended periods of time. Try to run it out or drain the tank.
Jul 28, 2014 | Water Sport
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
I have a 2009 Yamaha VX Cruiser waverunner there is a very strong gasoline odor when I lift the seat to check the oil or do other maintenance I'm wondering if this is normal, I bought it used it only has...
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
Oct 28, 2013 | Yamaha 2009 WaveRunner VX Cruiser
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
Need Help On A 1994 Yamaha Waverunner 3
Check your pump and impeller, then trace water inlet hose from back to front, possibly have a flush kit thats missing the cap?
Apr 30, 2012 | Water Sport
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Rooster tail is not shooting high
If the waverunner is performing normally as far as throttle response and top speed, then the rooster tail not shooting as high as it used to indicates there is a restriction in the nozzle for the rooster tail, not a problem with the ski. Unbolt the rooster tail nozzle from the steering nozzle and inspect it for debris.
Jul 13, 2009 | Yamaha 12V Air Pump
Boating Logo
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
