Question about Dell Dimension XPS 400 PC Desktop
Computer won't turn on
Stays in power save
  • Dell Master
  • 998 Answers
Powr suppky or motherboard is defctive.
Posted on May 06, 2014
Riptunes mp 1874R won't charge
Mine wouldn't charge and it Was New out of the box .
as It Turns out My Laptops USB port looses power when the computer goes into Power saving mode which was set to go into a low power state to conserve its Batteries when not in use , That was preventing it from charging fully when It was plugged in and I was away from my computer.
Dec 25, 2012 | Audio Players & Recorders
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
Dec 19, 2012 | Philips 51PP9200D Television
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
My computer won't turn on
when it is blinking red it means its in sleep mode. at that time the fan is turned off by your computer to save power. Press the power button oce again and u should have it up and running.
Aug 15, 2012 | HP Computers & Internet
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Dell Inspiron 530 won't start, CMOS
Sounds like the CMOS battery is dead. You will find this battery on the mother board. It is a round watch battery, pull it and take it to a store like Walmart to get a proper replacement. I bet if you check your system time, it is wrong too.
Feb 20, 2012 | Dell Inspiron 530 Desktop Computer
My Sharp Aquuos tv won't turn on. It has power and will come on for a second or two, then goes black. The tv's power indicator is on and stays red
The issue here is with the power supply board, allot of these TV's are known for bad capacitors so you might want to check those out.
When a bad cap is present the TV will not function as normal so keep that in mind.
A best resource for bad caps www.badcaps.net
A $2 cap could save you hundreds in repaires.
Please do not forget to leave a postive rating before you leave,
Rulds2008
Sep 20, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
Dell Dimension XPS 400 PC Desktop Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
