Can charge my laptop when its running - Computers & Internet
    Novelist:
  • 97 Answers
Yes
Posted on Feb 22, 2012
Won't charge
Not really enough info here but I'm assuming you have a laptop that won't charge?
If the laptop runs while plugged into the AC power adapter but will not charge the battery, the battery will need to be replaced.
If the laptop will not run with AC adapter AND it won't charge you should test the AC adapter to confirm operation. It may be faulty. If it's not you likely have a bad system board on the laptop and should replace the laptop.
Microcenter.com has very good refurbished laptop deals that may suit your needs.
Feb 06, 2016 | Computers & Internet
Charging led blinking
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
Dec 02, 2012 | HP Pavilion dv9000z Notebook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Mar 12, 2011 | Advent Netbook
My battery charges but the laptop wont run on the battery
If your power adapter appears to be charging your laptop battery, but the laptop will not run on the battery or only runs for a short time this usually indicates that the battery will not hold a charge and needs to be replaced. Although it should run fine with the power adapter connected.
Jan 26, 2010 | Dell Inspiron 1521 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Dell laptop doesnt charge only runs on ac power
How long have you had the laptop as all batteries even rechargeable have a limited life span. Dell laptop batteries normally have a life span of 1 to 2 years, so you may need to buy a new one
Apr 19, 2009 | Battery Technology Computers & Internet
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
