Question about JVC Car Audio & Video
How to instal a DS-FO001 adapter - JVC Car Audio & Video
Can't find a 2" eyepiece
That's because it is probably a 1.25 inch focuser. However this adapter will allow you to use 2 inch eyepieces-
http://agenaastro.com/blue-fireball-1-25-2-eyepiece-adapter.html
OR replace your entire focuser assembly with a 2 inch focuser.
Nov 17, 2010 | Meade DS-90AT Telescope DS-90AT
My ds is not turning on
How old is it? Test your adapter with mutimeter and make sure it has correct voltage or try a different one. Try your adapter on a different DS. Sounds like battery needs to be replaced.
Nov 20, 2009 | Nintendo DS Lite Console
Can this driver give out a wireless signal? I want to connect my Nintendo DS to it.. But I don't have a CD for it or anything. I use Windows XP.
No, it cannot. a driver cannot give out wireless signal. you need a wireless router to do the wireless signal or an access point.
Oct 18, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
My ds cant find my wi-fi adapter
dont worry ppl i fixed it, i found out that my internet connction that was going through the W-Fi adatper, wasnt accepting echo requests. but it works now.
Jun 12, 2009 | Nintendo DS Console
To use Nintendo DS lite in India
The easiest solution is to buy a UK one and buy a UK-to-India plug adapter.
They use the same voltage as the UK (240 Volts, alternating at 50 cycles per second [50 Hertz]).
Using a US adapter in India could blow the adapter or DS.
Aug 22, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo DS Adapter
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Mar 26, 2008 | Nintendo DS Lite Console
Nintendo DS connection
http://www.nintendo.com/consumer/wfc/en_na/ds/wrSetupHelp.jsp
Dec 26, 2007 | Belkin Pre-N MIMO 802.11g/b (F5D8010UK)...
Nintendo ds lite the adapter is stuck in the port
never do things like that.did your ds lite come with a ac adapter?did you check in the box?if not call the nintendo experts 1-800-255-3700.they will either take it out and send it back to you or give you a new one (and u must pay if they cannot take it out)
Dec 25, 2007 | Nintendo DS Lite Console
Car Audio & Video Logo
66 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
