Question about Zynga Texas HoldEm Poker
Zynga poker missing plug in
Program will not load, Just a black screen with missing plug in
earllan
  • 26 Answers
SOURCE: i was banned from playing
just contact the zynga and make an explain the whole story why your ban..
Posted on Apr 13, 2011
  • 11 Answers
SOURCE: ok i was on zynga
Have you tried updating Flash Player? You can go here to find the latest updates: http://www.adobe.com/support/flashplayer/downloads.html
Posted on Feb 28, 2011
SOURCE: Kode CA3 poker is not
kode CA3 remove please so i can play zynga poker again thank you
Posted on Apr 19, 2011
var90vr
  • 246 Answers
SOURCE: I changed my facebook email
contact me at var90vr@yahoo.com my friend
i will help u,How many chip do u have ? Would u give me at 30% from your chip, if i can open your account ?Thx anyway
Posted on Jun 10, 2011
salvo_riggi
SOURCE: hi, i'm trying to
HI did you fix the problem ? Error while loading page from Texas HoldEm Poker
Empty response received. SOmeone help !
Posted on Dec 25, 2011
A885GM-A2 new mother board will not boot up screen
You are missing the driver for the monitor. It should have come up but sometimes all the drivers are not or do not activate. If you have a disc for it run it and try to activate the monitor. It could also be the type of hook up you have. Make sure the cable is connected in the right port and that it compatible with your monitor. Might try the user friendly controls on the monitor. Make sure the contrast or black and white settings are not blacking the monitor out. Then there is always the possibility that you have a bad MB. Everything can work and it have a bad monitor driver as a matter of fact I have seen a lot of new and especially refurbished boards that were missing drivers. Also if you have the disc for the monitor you may have to run it again and it should program itself to the MB. Sometimes that has to be done. I have two monitors an Acer and a Dell and every time I have a hard drive go out I have to reprogram the Dell monitor. Try these things and let me know what results you get.
Later-
z
Mar 17, 2014 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
My dell inspironb120 powers up screen flickers on then black but when i attach to external monitor monitor works but laptop screen stays black when ichecked programs file it tells me i am missing drivers
If it flickers on as in you see an image, it's not the inverter. If your image is there but you can only see it if you hold it up to a strong light, then it is an inverter issue.
Your internal video driver may be missing or corrupt. If you have driver issues, plug in the external monitor and go right to the Dell website, click Support, and have the system locate your service tag number. The service tag may also be on the bottom of your laptop unless the sticker fell off. You will need this to get the correct drivers. Once you get a list of drivers, look for the video driver.
Jan 03, 2014 | Dell InspironTM 1501 Notebook
Dropped Canon - Display Broken
Repair expensive, if possible. Replacement best option.
May 25, 2017 | Canon PowerShot SD600 Digital Camera
Wont work
Was the light on the camera on (Green)??
If not then ensure it is plugged in.
Or load driver, DO NOT plug in when loading driver.
Mar 10, 2010 | Microsoft LifeCam NX-3000 Personal Web...
I have a 2006 nissan altima that misses while driving
Misses that occur only under load are typically spark related. Engines typically need about 8000 to 12000 volts of spark energy to idle, but under load and acceleration, they can require as many as 30,000 volts. Weak coils frquently can still make 10-15000 volts, enough for light cruising and idling, but insufficient for load. Further, a defective boot or carbon tracked sprak plug may fire normally at idle and cruise, but "arc" down a black carbon track in the plug porcelin under load. You should take the car to someone who has the equipment to propely examine misfires. Or if you really feel the need to do it yourself, you could try pulling all spark plugs one at a time( assuming you dont have a scantool or trouble code data to point you to a specific cylinder) and visually inspecting them. They should ALL be clean and dry and white all around. If you see any black lines or marks in the porcelin of any spark plug, replace both that plug, and the wire or coil boot attatched to it. If you dont see any dirty or wet or oil soaked plugs, you likely have a weak coil that will require scan, scope, or load testing to isolate. Most professional shops have the equipment to do this.
Sep 15, 2009 | 2006 Nissan Altima
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Acer aspire one notebook need urgent help please!
You need to restart the system again and press the F8 key, this should allow your to boot to the last know working configuration. Then you can put in the correct code. Please rate response.
Feb 17, 2009 | Acer Aspire One PC Notebook
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Jan 26, 2009 | ASUS Eee 4G Notebook
I need to shut down spy sweeper and reinstall - how do I do that?
Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally
Nov 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Restore computer
Before doing anything start your PC and keep pressing F8 slowly. A screen will appear with options choose Last Known Good Configuration to see if it cures your problem.
Aug 19, 2008 | E-Machines eMachines Desktop PC
Zynga Texas HoldEm Poker Logo
394 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
