Back to:
Tags:
Jenn-Air JBL2086HES Bottom Freezer Refrigerator
The refrigerator compatrment won't cool but the...
posted by Curt on Aug 26, 2006
My Jennair is less than two years old and on Friday my food spoiled in the top refrigerater compartment. The bottom Freezer compartment is working just fine with no problems at all. In addition, the bottom draw in the refigerater below the fruit & vegetable campartment is working just fine. I think it is either a fan or the temperature control.
After I write this e-mail I'll see if I can identify the fans to see if that is the problem. What I'm looking for is detailed information on how to narrow in on the problem and if it is possible to self fix it.
Thank you in advance,
Curt
Comment by Curt, posted on Aug 26, 2006
After some further investigation my brought to my attention that the compartment undet the fruit & vegetable draws has it's own temperature control. This leads me to believe the problem is the temperature control. If it is the Temperature control tan how do you replace it and can it be done by myself?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
catriver
Rank:Guru Guru
Rating: 94%, 2647 votes
Curt, I think you were on the right track with your first post. Check to see if the freezer fan is running. Then take a look at the back of the freezer and see if you have a big frost build up on the panel. The fan should be running moving the air to the upper compartment. If you have a big frost up on the back panel, you would have a difrost issue. Check these things out and post back..Catriver.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on The refrigerator compatrment won't cool but the Freezer works:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
evaporator coil don't work
Refrigerators
automatic ice maker in upper freezer compartment leaks...
Refrigerators
I have an RCA Refrigerator/Freezer mod # MTX18EAXJRWH. The...
Refrigerators
what size/type of globe do I need for a Kelvinator cyclic...
Refrigerators
miele fridge freezer kfn8862sd:back of fridge section full...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
