Question about Samsonite Photography
Forgot combination of Ventura AirNita suitcase
jessee007
  • 306 Answers
SOURCE: forgot my combination to my sansomite suitecase
a local lock smith can help but by now you have busted the hasp
Posted on Jan 01, 2008
SOURCE: change luggage key combination
I had the same problem, basically I went through all combinations starting 000, 001 ,002 etc. Ok it took a couple of hours, my fingers were sore but cheaper than buying another one !
Posted on May 26, 2008
SOURCE: suitcase number locked combination forgotten
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
Posted on May 29, 2008
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
Forgot the combination of my suitcase
Give you're suitcase to a small child promise them a gift if they can work out the combination to open it, like magic they will open it for you.
Jan 21, 2016 | yu shan Lojel Wave Polycarbonate 19....
How to reset built in lock on my Delsey Helium suitcase
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
Jan 07, 2016 | Delsey Helium Shadow - 25 Trolley Luggage...
I forgot my combination (three digits) to my champs suitcase
Try videos on the internet on how to unlock suitcases with three digit locks - there are quite a few. Good luck.
Aug 25, 2014 | Photography
Luggage
most default combination is 000 or 999, try it once. if all else forget, you need to do from 000-999.
Apr 27, 2013 | Luggage & Travel
I have forgot the combination. How can I open my briefcase?
Don't know how to help with a suitcase problem...I can help with FAX problems.
Mar 28, 2011 | Office Equipment & Supplies
Forgot suitcase lock code for antler
Unless you want to take it to a locksmith, who can open it in a few seconds, youu can run through all the possible combinations (there are only 1000 of 'em. You may get lucky, and hit a combination that represents something significant to you, such as an anniversary, birthday, or other important number.
Dec 26, 2010 | Locks & Locksmithing
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Oct 16, 2009 | Samsonite Tripod
Presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Jan 14, 2009 | Extensis Suitcase X1
Forgot my combination to my sansomite suitecase
Dec 07, 2007 | Impact 800 Tripod
Photography Logo
318 people viewed this question
Top Samsonite Photography Experts
isaac johny
isaac johny
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
