Question about LG Cell Phones
How do you reset the lg imprint - LG Cell Phones
    Top Expert:
  • 1,575 Answers
Hi
Note that resetting your phone will delete all data and applications downloaded or added restoring to its original factory settings.
Press on menu,
  • Select ' 7' then ' 9' then enter your four digits lock code which is simply the last four digits of your mobile phone number.
  • Now select on RESTORE DEFAULT and then press OK to confirm.
  • Select 'REVERT' and then enter your lock code again.
The phone will reset and then afterward restart on its own.
Here's a video review of your phone,
Hope it helps.
Posted on Feb 21, 2012
Master reset lg imprint mn240
you have to go to setting then you have to go to backup and reset then click on factory reset to master reset
Jun 06, 2017 | LG Cell Phones
I forgot my security code on my lg imprint is there anyway for me to reset it?
Hi..
You can get the unlock code by contacting your current service provider customer care department. If your phone is locked you can use any of your friends phone to make this call.
The service provider will then provide you the unlocking codes. Everything is done for free of cost and you are not going to be charged for this process.
Another alternative is, you can take the phone to any authorize phone service center to help unlock the phone, because to unlock your phone, you will need some kind of software, USB cable etc to unlock the phone, so you can also go a nearby phone service center to unlock the phone, but calling your network service provider is the best because they have the records of your phone and can easily help to unlock it. This are the two reliable means you can unlock your phone..
Apr 06, 2011 | LG Cell Phones
How to reset password on my LG Imprint phone i forget the one i used..
my lg imprint dose not have service and i locked my phone and forgot the unlocked code, how do i get it unlocked
Feb 04, 2011 | LG Cell Phones
Steps to unlock a metropcs lg imprint mn240
Hello, For Unlocking your phone, you may visit to your service provider LG Metropcs MN240 Unlock Code. I suggest to visit LG Unlock Code site, they will provide an accurate code with easy to follow instructions on how to unlock your phone fast without hassle. Once your phone is unlock, it will work with any network provider worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Feb 02, 2011 | Cell Phones
I need to change the signature imprinted at the bottem of every text message i send please help
In the Settings of Messaging you will come across an option if you want Signatures on messages. Select No here.
Sep 21, 2010 | LG enV VX9900 Cellular Phone
Is it possible to install java on my lg "imprint" mn240?
No; Unfortunately this will not be an option for this particular unit. the MetroWeb software installed on your unit has its own Java clone technology and it is geared to the MetroWeb format.
The original Java platform will not function on your current device.
Aug 23, 2010 | LG Cell Phones
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Cell Phones Logo
122 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
