Question about Uniden Cordless Phone
Showing "out of range" in motorola L603m we just disconnected the it and connected again.
Why am i unable to connect to my motorola L603m and theres no power supply
Contact The point of purchase. The phone should come with a charger. Or you can contact Looking For Help to find a replacement.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility L603m Digital Cordless...
3 way calling
most work like this, you make a call, ask first caller to hold, press flash, make another call, press flash again
Oct 21, 2013 | Motorola Mobility L603m Digital Cordless...
How can I add a 4th handset to my Motorola L603M?
I think you all totally missed the question. The phone set comes with the base and 2 extensions. He is wanting to BUY a 3rd extension for this unit, if I am reading this correctly. I have the same phone set and I have not found anywhere that sells additional handsets. Sorry.
Nov 22, 2012 | Uniden Cordless Phone
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 23, 2008 | Motorola Mobility HS815 Wireless Headset
Uniden Cordless Phone Logo
737 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
