Question about Singer 5050 Mechanical Sewing Machine
Bobbin thread does not rise singer 437 - Singer 5050 Mechanical Sewing Machine
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 27 Answers
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
Posted on Jan 10, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
SOURCE: Singer 301a Bobbin troubles
I just had this problem, too - if you have the manual, check out page 15. If you have removed the throat plate, you need to make sure that the position finger on the bobbin case base enters a notch on the underside of the throat plate. Fixed my problem right away.
Posted on Mar 12, 2010
Testimonial: "You are absolutely spot on! THANK YOU!"
Singer 4411 will not pick up bobbin thread.
If what you say is the case, the needle/hook timing is off. You can search the internet for sites or videos showing how to do this yourself or take it for service.
May 21, 2016 | Singer Sewing Machines
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
Test.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
Mar 17, 2016 | Singer CG550 Mechanical Sewing Machine
How do I fix it when the bobbin thread won't rise?
Make sure that your needle is ALL THE WAY up in the needle clamp and the flat side of the needle is away from you.towards the back.
Review the steps for inserting a bobbin in the bobbin case and raising the thread in your user's manual; if you don't have it, you can download it free at the Singer Sewing Machine site.
If you have done these things and you still can't get the thread to come up, then your timing has gone out of synchronization, and you will need to get a technician to reset it for you. If you cannot find a sewing machine technician willing to adjust a Singer, Sears supports all brands of sewing machine.
Jun 24, 2014 | Singer 2250 Tradition
Singer - 241-12, bobbin thread not stitching
I have a 241-12 Singer. New to me. It was running great. Then the bobbin thread ran out. Put in one prewound bobbin that came with it, even though the bobbin appeared different. The bobbin thread didn't feed and the machine jammed up. I finally wound the old bobbin and put it in. It will only feed about 6" of thread before the bobbin thread breaks. It becomes so tight I can't get it to feed. Both bobbins will not feed. However I don't believe it's the bobbin tension because thread will pull through fine when pulled manually (if it hasn't been in the machine yet). What am I doing wrong?
Sep 15, 2013 | Singer Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
Singer zig-zag 437
loosen the screw on the larger of the two feed gears (not bevel gears). Retigten so that the feed teeth start to rise right when the needle starts to rise and fall right when the needle starts to go into the fabric. Make the setting the same. i.e. when the feed teeth start to rise, how high is the needle (2mm, 3mm, etc.)? set the feed timing so the teeth rise and fall with the needle at the same height going in and coming out, this assures that the fabric only feeds when the needle is out of the fabric.
kent
Mar 18, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 600 touch and sew
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Oct 23, 2008 | Singer 3116 Simple
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Singer 5050 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
