Pandigital PANSCN03 Photolink Slide/ 35mm Negative Scanner/Converter wont load cd
Cd wont load. keep showing error!
SOURCE: film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jarek
Posted on Feb 15, 2008
mohanchennai
  • 490 Answers
SOURCE: Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Posted on Dec 16, 2008
dumbtrucker
  • 102 Answers
SOURCE: 35mm slide and negative adapter
First option would be the manufacturer, second would be EBAY for either the part, or a used unit with the part.
Posted on Mar 24, 2009
  • 8 Answers
SOURCE: Loading negative film in holder.
The button under the top door is for ejecting the film strip. To load negatives you just insert them until the machine recognizes them and then it will automatically load them.
Posted on Oct 11, 2009
SOURCE: i need the drivers for the hammacher schlemmer
i am not sure but you might look at vupointsolutions.com downloads for FS-C1-VP
i thin 64 bit not thre tho
Posted on Nov 11, 2009
Want to purchase some photo sheets
This is a scanner not a printer. You put photographs or negatives into it and it saves then to SD card or USB.
Pandigital Photolink One Touch PANSCN05 4 Inch x6 Inches Photo and Slide...
Jan 18, 2016 | PANDIGITAL PANSCN05 Photo Scanner with...
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Why won't my Pandigital photolink scanner scan
You must install drivers. If drivers are installed, take it to repair shop on warranty
Oct 11, 2014 | PANDIGITAL PhotoLink PANSCN06
Download panscn02 software
why my win7 isn't reading my pandigital tried everything carl
May 15, 2012 | PANDIGITAL Panscn02 Photolink Scanner
Scanning photo's on Pandigital Photolink - One Touch Scanner. Scanner is only scanning approximately 1/2 inch of photo
check the set up procedures of the scanner and select the proper size of paper. it sounds like the setting is wrong
Feb 19, 2011 | Office Equipment & Supplies
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
297 people viewed this question
k24674
jasbo
jasbo
