Question about Crate CA6110DG Gunnison Acoustic Guitar Amplifier
Where is the serial number on a crate amplifier
Need to give loud technologies the serial number so i can get schematic on an out of warranty amp but i can't locate the serial number on the amp
    Genius:
  • 1,212 Answers
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Posted on Feb 21, 2012
5 Suggested Answers
danforddan1
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
  • 7 Answers
SOURCE: bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Posted on Jun 28, 2009
  • 5603 Answers
SOURCE: Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either DigiKey.com or Mouser.com
Posted on Mar 23, 2010
SOURCE: Crate GTX-30 Guitar Amp Schematic... The thing
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
Posted on May 31, 2010
I need schematics for this amp. know where I can get them?
Josh,
I also need schematics for this amp. How about whoever finds it first shares with the other?
Cool, Thanks,
bob at stumpweb.com
Jan 27, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Volume fading in and out
If you play this loud the amplifier MAY be going into a thermal pprotection area. It would be about as loud as a typical boombox when at safe levels.
If you need louder than that, you need a bigger unit.
If the volume always is strong after letting it rest and cool and then fades as you drive it hard, this is the probable cause.
Aug 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
When i play on my line 6 amp (15 watt), the distortion doesn't work at all, like i tried using a number of different cables and all of my guitars and i get the same result. It basically sounds like i'm...
Since you have tried all external possibilities, this will require troubleshooting. If you are not adept in electronics, you best take this to a shop familiar with this model.
If I were troublleshooting this, I would suspect the power amp transistors or connections to them might be bad, but the testing would likely use an oscilloscope to trace the signals in an expedient manner..
One schematic for Crate I found uses darlington transistors TIP142 and TIP147.
Jul 29, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
or
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Mar 23, 2010 | Crate Music
Bass amp blowing fuses
Hi
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate CA6110DG Gunnison Acoustic Guitar Amplifier Logo
435 people viewed this question
Top Crate Music Experts
rjivaro
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
