Question about HP Computers & Internet
Laptop screen flickering
LCD screen flickering and going black
  • Jack Feb 21, 2012
    I wondered if it could be the backlight because I can see my desktop icons and the mouse cursor very faintly on the screen. If I use a flashlight or a lamp I can see just enough to shut the computer down etc... I just hooked up an external display and it works fine so I don't know if it's the lcd cable or the inverter or the backlight. This started with faint horizontal lines across the bottom of my screen. Then it began to flicker. Then the flicker became worse and eventually went out or very dark. Sometimes the flicker would stop and the screen would be stable but the longer the computer was on the screen would go off so that led me to believe heat was possible a factor too.
    Thanks for the reply. I've heard that the lcd cable can get worn in the place where these hinges are on the dv6000 series hp pavilion laptops. Does any of this tell you any more or give you a better idea of what the problem could be? Any help is much appreciated.
    thanks.
    Problem Solver:
  • 7 Answers
The video inverter may be failing, BUT...
More than likely the backlight is failing. If you can still see a VERY faint image on the screen this is almost certainly the problem.This is a very difficult fix. I recommend a replacement LCD.
It MIGHT be a bad lcd cable. With the laptop on, slowly open it from closed to open and back again and see if there is a position where the laptop screen does not flicker or turn off, [or if it does turn off if it turns back on.
If the screen goes COMPLETELY black then your GPU is failing.
Posted on Feb 21, 2012
Testimonial: "This person has been very helpful. Clear and concise."
  • 1 more comment
  • comitatus1 Feb 21, 2012
    In order of expense, here is what you have before you:
    1. Get a new inverter.
    If that doesn't help...
    2. Get a new backlight...but really this means get a new LCD because backlights are very difficult to replace.
    But I wouldn't bother doing either because it sounds like your GPU [Graphics Processing Unit] is failing, as evidenced by the slow degradation of the image on your external monitor.
    I would say it's time for a new laptop. If you really like the model you have, you could always look for an identical model on Ebay and find one that doesn't have a hard drive. When it comes, simply slip yours in and it will be good to go.
    Chris
  • Jack Feb 22, 2012
    I didn't mean to suggest that the external display is not working fine. Using a different display, I have no issues at all. My guess was the inverter just from the little research I've done online. So with a new LCD would that include the inverter?
    And if it was the inverter would my external display be functioning fine?
  • comitatus1 Feb 22, 2012
    I misunderstood you, then. If everything is working fine on the external monitor then you either need an inverter or a new lcd. The lcd panel and the inverter are two different parts, so while I'm thinking it's the lcd backlight which is the problem, I've seen just enough bad inverters to advise you to get a good inverter first and try it. It is relatively inexpensive compared to a new lcd.
Flickering screen
Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Mar 28, 2012 | ASUS U52F-BBL9 Laptop
Hi, The right side of my screen has gone black and does not display. When i turned it on it, the right side flickered for a short time before going black. It is a Asus Eee PC 1001PX. Please...
Make sure your desktop resolution is set to the maximum supported by your netbook. The flickering, however sounds like your LCD may be shot. If it's still under warranty, contact the manufacturer. If it's not under warranty, you should be able to Google for your laptop model and "replacement LCD". It's not too difficult a process to replace the LCD, but does require a bit of finesse.
Dec 10, 2010 | ASUS Computers & Internet
After turnoing on my sl500 the screen flickers and turns black
Check your video adapter settings. try to set it on clone and see if the picture would appear the same on your LCD. From there you select it back to your LCD. Just make sure the primary display is set to your LCD and apply the changes.
Hope this helps.
Dec 20, 2009 | Lenovo ThinkPad SL500 - Intel Core 2 Duo...
Is on but black screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Laptop screen flickering in hp laptop. had it for 1 year. screen stays on but flickers black very quickly
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 05, 2009 | HP Computers & Internet
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Screen goes black when plugged in
The high pitch sound is most likely a faulty inverter. Most defective screen are caused by a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Dell Inspiron E1505 Notebook
HP pavilion notebook screen turns black after flickering
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Jun 01, 2009 | HP Pavilion DV5Z PC Notebook
Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
May 08, 2009 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
209 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
