Question about HP Office Jet 4500 G510n
Hp officejet 4500 error 244
Wont finish recieving faxes
  • 138 Answers
SOURCE: Hp laserjet 3050 fax report
The error 244 results from a fax machine communicating and trying to 'Poll" your fax. (receive information you have loaded into the fax memory for all to receive) The error comes in when your fax has no information or is not set up to be polled.
Look in your menu for the "ECM" setting on the printer menu. If this error is getting persistent change the ECM setting to the opposite of what it is set now. More than likely your fax will say ECM=On, change to off.
If you have problems locating where the ECM section is, print a "settings report" or "printer menu".
Hope that helps you.
Posted on Sep 05, 2008
  • 4 Answers
SOURCE: NOT CONNECTING
Hi, have you connect your OfficeJet to one of your telephone outlet using a phone cord(usually provided with a AIO printer)? Fax requires analog phone line to operate. If you have a corded phone, you could disconnect it and hook it up to your OfficeJet.
Once you got it hooked up, try dial a # to your cellphone so you know it's dialing properly.
Good Luck!
Tony
Posted on Jan 09, 2008
  • 121 Answers
SOURCE: Our HP Officejet 5600 won't receive faxes.
hi
This error appears cwhen your fax is not working properly.WE can help you to fix it out if you can visit at----http://tinyurl.com/ng46w9
Posted on Jun 22, 2009
  • 73 Answers
SOURCE: HP Officejet 9130 incoming faxes are not being
If the faxes are not printing or are printing incorrectly
Check the media supply.
- The all-in-one cannot receive faxes, if it is out of media and its memory is full. Load media. The all-in-one will print all of the faxes that it has saved in the memory and will resume answering fax calls.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Nov 26, 2009
  • 42 Answers
SOURCE: Fax log full HP Officejet 8500 error; Delete not
Please press the set up menu on th eprinter which is like a tool(wrench)-----Arrow keys-----TOOLS-----OK-----Arrow Keys------Clear Fax Log------OK.
This will clear the fax log.
If still the issue persists, please follow the below steps.
1. Touch the Setup icon.
2. Scroll to and touch Tools.
3. Scroll to and touch Restore Factory Defaults. A Defaults Restored message displays.
4. Press the Cancel button to return to the main menu.
And then, again cleasr the fax log by following the below steps.
This will fix the issue.
Posted on Apr 12, 2010
How can I get a parts manual for Hp officejet 4500?
the challenge is that many of the parts are not available at all so a manual would likely be of no use. You can check a site like this Feedroller HP Feed Rollers Printer Parts HP Laserjet Feedrollers
but I do not think they have inkjet parts.
Jul 25, 2015 | HP Officejet 4500 All-in-One -...
HP Officejet 4500 scanner does not work
there is a service manual for this family here http://www.maisiemanuals.com/product_info.php?products_id=4975
It might help you to solve the problem
Jan 02, 2015 | HP Officejet 4500 Wireless All-in-One...
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I'm getting an error 244 or 223 when receiving a fax. the fax only partially prints out
Error 244:
Definitions
  • The user of the remote machine pressed the Stop key, causing the session to be prematurely terminated.
  • The remote fax machine determined that there was a feature incompatibility between the two machines and terminated the session. For example, the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solutions
  • Make sure that the remote machine can accept and use polling.
  • Select a slower reception speed.
Error 223:
Definition
The local machine was unable to receive an entire page even after multiple attempts to receive the parts of the page that contain errors. This situation is usually due to extremely poor line conditions.
Solutions
  • Try to receive the fax at a different time when telephone line conditions have improved
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My m1522nf keeps erroring out with errors 244 and 344 while receiving faxs. It also will not send more then 6 pages. Any Idea's?
These are typical comm errors, try installing a line filter and turn the ecm mode to off and the fax speed to medium.
Al
Oct 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error Code 244
It seeme the fax no you are trying to send fax does not receive fax in higher speed or might be it is a older fax machine than the one you have.
Try reducing the fax speed on your machine and trun off ECM mode.
Press Menu / Setup> Press the right arrow key till you see advance fax setup> and press Ok> Again press the right arrow key to locate fax speed> and press Ok> and reduce fax speed to slow> Press Ok. and cancell to come back to the main screen.
To disaable ECM mode>
Press Setup .
Press the Down arrow repeatedly until Advanced Fax Setup displays.
Press OK .
Press the Down arrow until Error Correction Mode displays.
Press OK .
Press the Right arrow > until either OFF or ON displays.
Press OK .
Check the link bellow for a detail of all fax error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=391194
Good Luck
Sep 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Office Jet 4500 G510n Logo
197 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
