Question about Vacuums
Eureka surfacemax 300 manual - Vacuums
4 Suggested Answers
SOURCE: Surfacemax 300 yellow eureka vac.
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Posted on Oct 29, 2010
Vac Belts
  • 701 Answers
SOURCE: how to change a broken belt on a eureka surfacemax
Here is some info that will help:
You need this belt:
Eureka SurfaceMax 300 Belt
This is the manual with instructions:
Owner's Guide
Posted on Jan 02, 2010
SOURCE: my eureka surfacemax 300 is not sucking up
I've found that some times if you let the cup get too full, stuff will get jammed up above it. Turn off the vacuum and unplug it, and remove the cup. Reach up inside the vacuum above the cup and there is a small, plastic cylinder you can twist to remove (twist and pull down). clean this plastic piece off, and reach up inside where it was located. Clean out that crevice as well. Vacuum should be as good as new!
(It shuts off because it is over heating from not being able to pull anything through there.)
Posted on Jun 13, 2010
Smells hot when running and will not pick up debris I recently cleaned all filters
Something is stuck in the piping system. The passing vacuum air is used to cool the motor. It's not getting that air so it will start to over heat and smell
Jan 09, 2014 | Eureka Surfacemax 200 Bagless Upright...
Is the replacement belt supposed to be really tight?
Yes.
Put it on the back first.Then on the brush.Put the brush in belt side first then pull the other end in place.
Jul 12, 2011 | Eureka Surfacemax 200 Bagless Upright...
I need help to locate the belt on the vacuum please
flip the vacuum upside down and take cover off might need a phillips screw driver belt should be there on the brush roll once you remove the lid
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
My son vacuumed up water. I am trying to open up the cannister & dry out, but am unable to get at all the screws. Is there a manual available that would show how to get at all the screw locations?
you will need a flat screwdriver and a little patience to get to the screws.
you will want to remove both the switch cover and the cord retract cover to get to the screws. once you have done that, you can get into the motor chamber area and dry that unit out.
Good luck,
Mark
Nov 06, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
My eureka surfacemax 300 is not sucking up anything and i have cleaned out the hose plus i turns off by itself sometimes
Apr 16, 2010 | Vacuums
How to change a broken belt on a eureka surfacemax 300
You need this belt:
Owner's Guide
Jan 02, 2010 | Vacuums
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
644 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
