Where do I connect my mouse cable into the monitor?
The mouse cable is just a normal length and I've always been able to plug the mouse cable either into the monitor or keypad. It appears on this computer that I can only see a possible connection into the hard drive which is under the desk and too far away from the mouse. Can you help please
  • 3 Answers
You need a USB extension cable or a USB hub with a long cable
Posted on Feb 23, 2012
Acer Aspire wont clone display on monitor
It is very possible, software not included, it happens like microsoft and their new progs, somehow they miss old friends of until we complain.
Try a download update.
Jan 28, 2013 | Acer Aspire TimelineX 5820T-5951 Notebook
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
I bought a x2gen mg5r4 monitor at the goodwill I've got a power adapter that supplies the proper voltage & amperage to the monitor. It powers up just fine, but when plugged into the computer it (the
If the monitor indicates "No Sync" Make sure your video cable is a high density DB15 end. If it is only 9 pins, you have a DB9 cable or connection. Also make sure the video you have it attached to is enabled and is also a high density DB15. (it will have 3 rows off pins. The DB9 will have 2 rows)
If those are okay it may be broken wire in the cable or on the monitor's DB15 connector/connection.
Dec 18, 2011 | Computers & Internet
I've had my Compaq Preario CQ80-410US for about 2 years now. There's been some issue with it overheating lately but I've been giving it breaks when it gets too hot. Last night I went to turn...
Hi
Sir as you describe the problem i don't think it has to do anything with overheating. Only this is open the LCD panel and check to make sure if the cable is connected to the LCD firmly, normally because we use the laptop a little rough the cable connecting to LCD from the motherboard normally get loose. And also do not forget that LCD replacement is also not ruled out here.
Jul 16, 2011 | Compaq Presario Notebook
When i connect the monitor VL2018W TO a power supply without connecting to my pc,i get the message ''NO SIGNAL,SELF DIAGNOSTIC'''.When i connect cable to pc,,there flashing blue light...
* Make sure the cable is connected properly.
* I've you have mutiple interfaces like HDMI & VGA, try switching between these until you get a signal :D
This can be performed by using the build-in options menu.
Jun 14, 2011 | Princeton Digital VL2018W Monitor
LG Studioworks 552V monitor incompatibility problem.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 06, 2010 | Computers & Internet
How do you turn a mintek tv into a computer monitor?
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Feb 17, 2010 | Dell Latitude D600 Notebook
Reverse KVM problems
If you are sure the left monitor?s power is not the source of the problem it does sound like a shielding or excessive signal loss in a device/cable. If it?s always the left monitor I would try unplugging the video cable that goes from the left monitor and plug it into the right monitor; do the same with the other monitor. If the problem moves to the right monitor then that eliminates the monitors and we move on. If the problem goes away then probably one monitor had more signal degradation than the other. If the problem stays then the monitor is the source of the problem. If the problem followed the cable then I would exchange the cables that run from the switch to the monitors; if nothing changes exchange the cables that run from the switch to the PCs. If exchanging any of these cables results in the problem moving then you have a damaged cable or a bad connection. If the problem is still on the left monitor unplug the cables from the left PC that run from it to the switch and plug them into the right PC; do the same to the right PC. If the problem moves then you might have a damaged switch OR perhaps the video card output on one of the PCs is weaker than the other. All cables and devices weaken the video signal to some degree but the amounts can differ wildly. Over the years I?ve had this problem caused by cables, switchboxes, video cards, radio transmitters, bent connector pins, poor connections, excessive cable lengths, monitors and accumulative signal loss from several devices. The last is the hardest to diagnose. Good luck and let us know what happens.
Jan 01, 2007 | APC Cables - KVM Products, Data Switches,...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
