Question about Copystar Office Equipment & Supplies
Was in working order at previous location, after the move, the touch screen is non responsive. Control panel buttons will select the different screens for copy, fax, print. Touching the screen doesn't provide feedback. It functions other than the screen being non responsive. I have removed the panel and reseated the connectors, with no change. My vendor says it may be the touchscreen or the control board in the back or? or? :) They have ordered touchscreens and sold them and have one in stock. I am wanting to be more sure of the probability of the touchscreen being at fault. Has anyone had this symptom and a new screen fixed it?
SOURCE: IP address for Copystar CS-3035
1.On the drivers CD You must have Quick Config tool.Just click on setup Icon and follow directions.
2.Or just press "printer"Button on the operation panel of machine.Go to Interface-TCP/IP and You will see IP adress.
You can also from printer menu select "print Status Page" and page will be printed.You can find IP adress on the status page.
Posted on Nov 28, 2007
SOURCE: HP X4270 5 YEARS
Step 1 Remove the power suppply from the back of the printer...
Step 2 press and hold the stop/clear button (the button with the red X)..
Step 3 Insrt the power supply into the back of the printer...keep holdin the button...
Step 4 The printer would display the language as english
Step 5 Select the desired settings
Vola ...ur printer should be back to normal...
Else contact on 1-800-332-4120
Posted on May 02, 2008
SOURCE: CANON IMAGERUNNER 330S TOUCHSCREEN
Start with service mode, Additional functions(looks like * key), then 2,8 together, then addit. func. again. Has to be a fluid motion. If done right you will see a screen with copier, and whatever options the copier has. Hit copier key. Hit function key. Hit panel key. Hit touch key option, hit OK. Then touch the nine + signs. once complete. press reset to get out and test results. Hope this helps.
Posted on Jun 13, 2008
Apr 07, 2016 | Janome Memory Craft 9000 Computerized...
Jan 04, 2013 | Copystar Cs-C2520
When you install a new Cs2520 you have to remove the three tapes holding the pins for light
source units 1 and 2.(scanner) To secure the scanner you would have to reinsert those pins if on the left side of the copier if you still have them. I assume you are moving the copier which is why you want to secure the scanner.
Aug 30, 2012 | Copystar Cs-C2520
Jan 13, 2011 | Garmin Nuvi 660 GPS Receiver
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Jun 17, 2010 | Garmin Nuvi 350 Car GPS Receiver
Jul 20, 2009 | Copystar Office Equipment & Supplies
Dec 07, 2008 | Nintendo DS Lite Console
62 people viewed this question
