Connection problem haier lt32m1c hdmi - Televison & Video
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Volume on my Haier tv L32b1120 Goes up and down by it's self
There is little to No info on this TV. I would say, the signal board is the culprit. You may also call this the main board. Either way, it is the board containing the RF, RCA, and HDMI connections . Thanks for asking me. Matt of Martins TV.
May 21, 2014 | Haier L32B1120 32 LCD TV
Haier 9" tablet HG-9041 will not boot up
Have haier tablet hg 9041 locked out ... How do a hard reset...
Feb 02, 2014 | Haier Move 2-Ipad 2 Dock With Hdmi
Haier TV buttons usually don't work
does it connect to the internet? most new tv's now connect to the internet. through doing this it should do an update and possibly fix any issues you may have.
hope this helps
Jun 17, 2013 | Haier HL26R 26 in. LCD TV
Haier L24B1180 24
Most new can now a days. In any case, took a quick look at your specs and simply connect to PC. Then choose input from TV. Like VGA, HDMI, depending on cable paring you choose for your PC video card. VGA is usually the easiest.
Aug 29, 2012 | Haier L24B1180 24 inches 1080p LCD 24 LCD...
Haier tv flashing green and red and does not come on
May be you have a faulty video cable from your cable set-top box or your DVD player--try changing the cable to see if it fixes the problem.
Also, is the video cable an HDMI cable or component (like RGB)? If it is a component cable, it may be they are connecting properly.
Aug 01, 2012 | Haier HL24XLE2 LCD TV
I just reconnected my haier television to the cable box and now the picture is in black and white not in color
U are using a AV RCA cable for the connections?Ur AV RCA cable connections all matches up like RED to RED,YELLOW to YELLOW and WHITE TO WHITE?Tried another AV RCA cable?Might even tries a HDMI cable for the connections?U tried all these still getting the same result no colors,just black and white.Than ur Tuner board is defective,must be replaced to solved this problems.
Apr 24, 2010 | Haier HLH406BB 40 in. LCD HDTV
Hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Jan 16, 2008 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
