Question about Pioneer Car Audio & Video
By doesn't my radio keep andy memory
I would check to make sure the continuous power wire is connected. Then I would check the fuse for the radio.
Posted on Feb 21, 2012
I don't have the code of my radio
We do not have access to the radio security codes, please see your local dealer.
Nov 06, 2012 | Cars & Trucks
I have a 2004 Nissan Quest. First, the speakers started popping off, then radio wouldn't work anymore. We pulled the fuse under the hood and reinserted it. When it sparks radio will come back on....
if you are having radio issues where you have to mess with the fuse to make it work i would say it is the culprit for the battery draw, a lot of radios trigger the eject when power is reconnected for the memory wire, that is not a problem with the radio.
try unplugging the radio and see if that fixes the battery draw.
Sep 27, 2012 | Cars & Trucks
Something fell into the cigarette lighter and it sparked now the radio will only eject and load cd's but it doesn't do anything else after that stage i checked and replaced the radio fuse and
you need to remove what ever dropped into the outlet then replace the power outlet fuse the radio uses more than one fuse memory amp and lights
Aug 06, 2012 | Suzuki Swift Cars & Trucks
First@gmail.com, 2006 malibu cd player keeps the cd, doesn't eject or take the cd, but plays fine. Is there a part I can replace myself?
Is it a burned CD-R? I know (this is probably the same on a 2006) that on my 2005 if you put one in, it will play fine then lock the disc in. There is a fuse pannel on the passenger side on the center of the console towards the front of the car. Just pull the plastic cover off. Find the 10A fuse by the little grey box, and a blue and white circle. (or just look for the fuse labled "RADIO" on the map inside the plastic cover and then locate it in the fuse box). Turn the key off, pull the fuse, turn the key back on for a sec and the radio will not come on. turn the key off, put the fuse back in and turn the key on. the disc should either come out or you will have to push eject. This may or may not work, some people say it doesn't work for them. (this may reset the radio number buttons memory). Hope this helps!
Aug 21, 2011 | 2005 Chevrolet Malibu
My blackberry 8520 keeps on saying my memory card has fatal errors and when I go on the computer the folder 'blackberry' doesn't show. My phone wont let me format or repair the card. I've...
Look on this forum:
http://supportforums.blackberry.com/t5/BlackBerry-Curve/Problem-updating-device-software-quot-Fatal-error-quot/td-p/82515
Jun 18, 2011 | SanDisk 2GB microSD Memory Card
I have a 2003 ford focus and my radio does not work. I have checked the fuse for it but there is nothing wrong. Anything I can do or check?
Check the detachable portion of the "faceplate" on the radio. It's where the memory buttons are. That sometimes doesn't get a good connection and the radio won't work.
Jun 01, 2011 | 2003 Ford Focus
Pioneer radio wont retain station memory
clock probably doesn't stay either.....sounds likke the wiring may be incorrect...there are 2 battery + leads on these radios...One is yellow...which should be hooked up to a hot lead that is hot all the time even with the key off( you could just run a wire to the positive side of the battery)..thios lead is the memory lead that keeps stations, settings, and the clock....then there is the red lead that is supposed to be hooked up to a switched positive lead...such as the accessory lead fron the ignition switch....it's a good bet that the red and yellow leads are hooked together and that they are hooked to a switched ignition lead right now...all you have to do is disconnect the yellow lead from where is hooked now and hook it to a hot all the time then your memory, and stations should be retained
May 10, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
My radio/navi keeps saying "it is not possible to operate this function while in memory navi mode"...how do i get out of that mode? thank you...andy
Sorry Andy, that feature is built in at the factory so you cannot watch a DVD while driving.. maybe a radio shop will know how to bypass it.
Nov 14, 2009 | Pioneer AVIC-D3 Car DVD Player
Car Audio & Video Logo
50 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
