Question about Fossil AM3424 Wrist Watch
Where can I buy a Watch band for Fossil Blue AM3424
SOURCE: link removal
here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
Posted on Aug 10, 2007
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
I did not know this was this easy, all this time with this problem. I like the internet.
Thanks!
Posted on Sep 04, 2008
escapement
  • 2334 Answers
SOURCE: Trouble sizing Fossil Watch CH-2506
Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
Posted on Jan 02, 2009
Hello, where could I buy, Fossil CE1000 BAND repair parts?
Can't, new watch time or at least new band time
Oct 12, 2012 | Fossil CE1000 Watch
Fossil AM3695 Wrist band
http://www.ebay.com/itm/FOSSIL-AM3695-BIG-TIC-KALEIDO-BROWN-LEATHER-MENS-WATCH-/150793269174
Jun 13, 2012 | Fossil AM3695 Wrist Watch
Second hand and battery replacement on fossil watch
Fossil watches have an 11 year warranty. Any jeweler can replace the battery. If that doesn't solve the problem and you registered the watch or still have the receipt call 1-800-TICTOC1 for repair.
Sep 24, 2011 | Fossil AM3424 Wrist Watch
I need the type of battery for a Fossil AM-3424.
sr920 is the size of battery of your watch.
Sep 07, 2011 | Fossil AM3424 Wrist Watch
Would you happen to have a watch band pin (link that attaches band directly to the watch casing) for a Fossil Blue Model AM-3515? Great difficulty locating one of these. Thanks for any help on this.
mcdevito75 here, This pin is called a spring bar, while I have many of these I would need the watch to match up the spring bar with the caseing. Best Bet, see a small watch repair shop in your area. Approx. Cost, $5.00 plus install.
Aug 18, 2010 | Fossil Watches
Ihave a fossil blue watch, and need links for the band. where can I locate some?
Contact Fossil customer care and they should be able to supply them. Here is their web address:
http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html
Aug 01, 2010 | Fossil Watches
Plastic band broke at the end where pin goes ,is f...
Go to their web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html and you will arrive at a page with ordering info. on how to buy new bands.
May 14, 2010 | Watches
2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Dec 08, 2008 | Fossil University of Oklahoma LI2282 Sport...
Fossil AM3424 Wrist Watch Logo
32 people viewed this question
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
