Question about Whirlpool Accubake SF362LXTS Kitchen Range
My temperature will not go past 260 degrees? - Whirlpool Accubake SF362LXTS Kitchen Range
2 Suggested Answers
  • 122 Answers
SOURCE: Can't set temps above 260 degrees
check in your owner's manual for the section on setting your control to fahrenheit or celsius. Then check to see if your control is set to celsius.
Posted on May 20, 2010
Testimonial: "WOW! Simple, but that's it! Thanks so much!"
Where can i buy a transmission fluid temperature sensor?
The transmission temperature sensor mounted on the overdrive/torque converter clutch solenoid assembly and provides input to the TCM. When the temperature sensor reports 30 degrees F or colder, there will be no overdrive, and below 50 degrees F, there will be no torque converterclutch. If thetransmission fluid temperature sensor reports an overheating condition (over 260 degrees F) and the transmission is currently in overdrive, the TCM will downshift to third gear. The TCM will also light the LED in the dash-mounted OD off switch until the temperature drops below 230 degrees F. However, the torque converter clutch may still be operational.
Aug 09, 2015 | Jeep 1999 Grand Cherokee Laredo
I have a 1996 chevy lumina and the temperature gauge keeps moving around unpredictably. The fans wont come on. We checked the fuses and relay switch. Could it be the fan motor, or temperature gauge
The gauge is supposed to move. Between 190 and 210 degrees. About a 1/16 to 1/4 inch movement with the needle. If it goes from middle(200 degrees) to hot(260 degrees) and back. Check the coolant level. Air pocket in the engine. Low fans come on at about 210 degrees. High fans come on at 225 degrees. High fans come on when the A/C is turned on. And it works.
Feb 16, 2015 | Chevrolet Lumina Cars & Trucks
Our oven will only heat up to 260 degrees it won't go any higher
It sounds like 260 Degrees c would be the max temp of your oven, its a pretty high temperature.
Apr 10, 2014 | Whirlpool Kitchen Ranges
Location of transmission temperature sensor 2002 liberty
on the transmission. 45RFE trans.?
is the engine overheating?
The transmission temperature sensor is mounted on the overdrive/torque converter clutch solenoid assembly and provides input to the TCM. When the temperature sensor reports 30 degrees F or colder, there will be no overdrive, and below 50 degrees F, there will be no torque converter clutch. If the transmission fluid temperature sensor reports an overheating condition (over 260 degrees F) and the transmission is currently in overdrive, the TCM will downshift to third gear. The TCM will also light the LED in the dash-mounted OD off switch until the temperature drops below 230 degrees F. However, the torque converter clutch may still be operational.
Mar 16, 2014 | Jeep Cars & Trucks
Low Temperature
250 is not low, it is just about to boil over, coolant boils at 260 in a closed system, water boils at 120.Your car should not exceed 200, 220 max. Or just 100 degrees over the outside temp, like 87 degrees out, your car should be running at 187. Until you stop at a light and it idles for a minute, then it will climb.
Aug 04, 2012 | Cars & Trucks
What is the average oil temperature for a 2005 harley fxdwg My bike runs between 220 degree and 260 degree
Well it depends on the ambient temperature. Your bike sounds like it's in about the correct temp range on the oil temperature. This is why Harley went to using synthetic oil. It has a higher breakdown temperature than petroleum based oil.
Good luck
Steve
Dec 19, 2010 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
May 20, 2010 | Whirlpool Kitchen Ranges
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Whirlpool Accubake SF362LXTS Kitchen Range Logo
331 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
