Question about Porter Cable Tools & Hardware - Others
How can I lubricate my porter cable 557 plate joiner?
Picked one up cheap on eBay, but it needs TLC. First impulse is to hit all the joints with WD-40, but there's probably a better solution. Note: I'm talking about lubricating the external parts, not the motor.
  • facebook42
    facebook42 Feb 21, 2012
    OK, this is a plate joiner; dunno why it got classified as a sander.
  • facebook42
2 Suggested Answers
SOURCE: My porter cable orbital sander, model 333 needs to be lubricated
how to lube sander
Posted on Jul 12, 2011
It wont vacume any more how do do i fix?
Make sure you have a clean bag in there, and make sure that the belt on it is working.
Dec 15, 2012 | Tilia Foodsaver V835 Vacuum Sealer
The nail striker is only partially extending from the head of the gun, misfires blanks now all the time. do I need to take the head of the gun apart and clean it? Or Is the striker shaft possibly broken ?
There is a face plate on the front of the magazine to aid in clearing jams. Sometimes this can be dislodged a bit causing the striker to not hit the brad squarely. It could be that some cleaning is in order....never ever hurts that's for sure and may help determining any bent / broken parts. Make sure the tool is well lubricated also.
Take care.
Dec 02, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Need copy of owners manual.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/891038.pdf this is for type 1,,,if you need a different type then go to http://www.dewaltservicenet.com/ in the middle is a section titled "need a manual?" just enter in your model number and it should pull it up or if you don't know off hand then enter 557 and it will bring them all up for type 1 through 4
Jun 13, 2010 | Porter Cable - Cable 557 Factory -...
Need an instruction manual for a Model 557 Porter Cable Plate Joiner
Owners manual is here. Exploded diagram is here.
I would like to note the manufacturers site lists 557 Types 1-4. Not sure what the difference between them is, but if you need the link, it's here on page 4 of 5.
If this answer helped, please vote. Thanks!
Apr 10, 2010 | Porter Cable - Cable 557 Factory -...
Is the thread that holds the blade in left handed or right? I can't get the screw loose!
Hello. Use some WD-40 on the screw and let it sit for a few hours. Then be sure you have a screwdriver that fits properly. As you look at the screw head, left is loose. Turn the screw head in a counter clockwise direction. Regards, Joe
PS - kindly rate my answer as helpful. thank you.
Feb 13, 2010 | Porter Cable - Cable 557 Factory -...
Blade change problem for Porter Cable 557 plate joiner
Putting it in the freezer for a couple of hours may loosen the screw by contraction and or you will have to use an impact wrench unless it is completely stripped , then you will have to drill it out.
Apr 08, 2009 | Porter Cable - Cable 557 Factory -...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
Tools & Hardware - Others Logo
19 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
