Question about Garden
How to fit the gard of Kingavon grass trimmer KGT1?
There is no manual to explain how to fit the gard. It seems that the spool has to be detached, fit the gard and then fit the spool.
5 Suggested Answers
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 246 Answers
SOURCE: can't find manual to 26ss mighty lite trimmer.
Hello jonandchima:
This is a Homelite Product.
You can Order a Manual from this Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information and Select "Need Manual" . Remember to Include the UT Numbers.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: adding trimmer line to spool on husqvarna trimmer-two strings
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
Trimmer wrapped around shaft
Deborah there should be a little hole just towards the bottom of the spool head where you could fit a small metal rod in. If you can locate it push something small in like a 2 inch nail and turn the spool head slowly by hand until it locks up. The head should then undo . It will undo anti clockwise.
May 14, 2014 | Black and Decker USA black & decker grass...
Spool cover required for hg500b grass trimmer
Hi, mine broke yesterday (Sovereign HG500B Grass Trimmer). I took the grass trimmer to Homebase but they've told me that this model has been discontinued and they don't sell spare parts for it. I believe it's still within the guarantee period so if I can find the reciept they'll organise some sort of replacement, but if I can find somewhere that sells a replacement spool cover I'd rather just buy that and replace it...so far no luck.
Aug 04, 2010 | Garden
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
I can't figure out how to replace my spool
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and
pulling away from unit. Replace empty spool with new full one or wind on aftermarket
string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Mar 14, 2010 | Black & Decker 14" Grass Hog Xp...
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
The shaft stopped turning
I have the same problem, the B&D service tech told me that the problem is the little gear that transmit power from the motor to the spool, it is made from plastic and just melt
Sep 28, 2008 | Black & Decker 14" Grass Hog Xp...
Garden Logo
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
