Question about Whirlpool WGD4900XW Dryer
Whirlpool Dryer Intermittent Buzzing - Gas Valve?
After one year of use, my Whirlpool gas dryer (WGD4900XW) has started to buzz intermittently. It only buzzes when on a "heated" setting - the buzzing immediately goes away when I switch it to "no heat". A service tech came out and said it might be the gas valve, as they make that buzzing/rattling sound when they are about to fail. He said to keep the area vented and make sure no gas smell is evident while using the dryer. He also said that a gas valve replacement is a pretty easy DIY project. Has anyone experienced/completed this DIY problem? (And, of course, the one year warranty expired a few weeks before the buzzing started...suppose I will start to buy extended warranties.) Thanks for the help, Joe.
SOURCE: Drum turns, but no heat
When I had no heat I changed the thermal fuse. You reach it from the back and is held in by 1 screw. It is a cheap place to start only $13. I also told someone at work with the same problem and it fixed the problem.
Posted on Nov 04, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
Posted on Jan 21, 2009
VOTIT
  • 2071 Answers
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
  • 119 Answers
SOURCE: How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Posted on Aug 21, 2009
garing
  • 998 Answers
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Posted on Aug 27, 2009
Maytag gas dryer. Loud buzzing sound when flame comes on. Buzzing stops when gas valve off. Replaced solenoids twice. Dryer works but the buzzing is annoying. Do I need to replace gas valve assembly?
While you are hearing the buzzing, tap the gas valve (gently) to find out whether the buzzing changes. If so, the valve is the culprit.
Feb 18, 2017 | Maytag Dryers
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Whirlpool Carbrio dryer buzzing noise while running. Works OK just keeps buzzing off and on while drying. Not a grinding sound.
OK, remove the 2 screws on the front lower kick plate. Run the dryer to see if the buzzing is coming from the motor or from the burner area. Post back your results.
Nov 09, 2012 | Whirlpool WGD5600XW Cabrio 27" Front-Load...
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Gas valve buzzing
gas regulator mate,between the supply and the appliance
Dec 23, 2011 | Whirlpool Dryers
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
Have a Whirlpool gas dryer, model #LGR4634JQ2, that will not heat anymore and has a rattling noise every now and then. Any ideas?
The rattling noise is maybe a sort of buzzing only more metallic? Sounds like the coils on the gas valve making it flutter. Causes are the coils and/or the ignitor.
Eric
Jun 07, 2009 | Whirlpool LGR7646E Dryer
Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Dryer
try new gas valve coil packs. They are inexpensive, easy to install and fix 90% of intermittent lighting complaints.
Oct 15, 2007 | Dryers
Whirlpool WGD4900XW Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
