Question about Amana Refrigerators
How long after turning a frig on side before plugging in to start running again?
Bottom freezer
3 Suggested Answers
  • 1314 Answers
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Posted on Jan 11, 2008
Sea Breeze
  • 4654 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
Maytag ptf216lhr
thermostate stuck in defrost mode. sometimes they are inside frig(were temp controls are) sometimes in bottom rear of frig. IF you can find it you will find a small knob with slit in it. turn it clockwise just a little and clicking will stop and frig will start cooling however it will probably do it again. recommend replace thermostate.
Jan 24, 2014 | Refrigerators
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less...
you may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Aug 22, 2010 | Refrigerators
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
The fridge section is getting too cold at the bottom
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig side by side problem
I rolled the frig forward enough so I could unplug the power cord from the outlet. Then
I removed the freezer back panel and found the evaporator coils completely encased in frost. I used hot water in a 20 ounce sqeezable water bottle to remove the caked frost from the coils. I used the back panel as a chute to route the water into a large square bucket I placed on the floor right in front of the freezer. I then disconnected the defrost heater and checked continuity with my meter on the Rx1 scale. Meter needle did not move when connected across the heater indicating that the heater was bad. Called the local parts supplier and gave them the numbers off the old part. They had it in stock for $27.31 so went and picked it up, plugged it in, put in the mounting screws, replaced the freezer back panel, and plugged the frig in. I turned both the freezer and frig thermostats to their normal position. Four hours after my better half got all the food back in the freezer and the frig, the temperature in the refrigerator was 36 degrees.
Feb 28, 2008 | GE GSH25JFR Side by Side Refrigerator
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
