Error code 39 dvd/cd-rom drive
Am unable to locate it on my computer.when going into device manager it says that it might be corrupt or damaged, but even after deleting it and rebooting, or trying to use the auto updater nothing changes im still left with a yellow triangle with an explanation mark in it and still no drive.im pretty sure the firmware that the drive was running is version 1.01 but i cant find it on the net.
  •  ajay
    ajay Feb 22, 2012
    yeh hi thanks for that. ive already got slim drivers and it could do nothing for me.However the gd news is ive fixed it,i down loaded a fixya solution and it worked straight away. Thanks anyways.
  • 324 Answers
SOURCE: CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Posted on Nov 09, 2007
IB4G2008
  • 3587 Answers
SOURCE: GMA 4082n device driver not working properly code 39
sounds like your cd/dvd is mechanically shot. time for a new one.
Posted on Mar 09, 2008
  • 351 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Dear NICK,
its a windows registry related problem, you can fix it through :
This method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Posted on Mar 24, 2008
  • 351 Answers
SOURCE: DVD/CD-ROM driver does not not run any types of disc.
Dear Xu Ling ,
Its O.S. related problem please try to install this drive on another Computer and i'm sure it will works perfectly. in this case you have to re-install the OS on your Existing Computer, if you wanna use it on your own PC.
Takecare
Posted on Mar 26, 2008
  • 97 Answers
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Posted on Sep 16, 2008
Cd player not responding
Look for firmware at the manufacturer's website. Did you check in 'hardware' for problems? You can try reinstalling the driver there.
Right click on 'my computer' > properties > hardware > device manager > double click on your cdrom.Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.Go to device manager:
When in device manager, look for:
IDE ATA ATA/ATAPI controllers
click on plus sign to expand the tree
right click on the IDE controller that is handling the CD/DVD drive in question
select uninstall
reboot your computer
Nov 21, 2011 | Car Audio & Video
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful. To solve this Code 39 error, follow these instructions:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Another possible CD/DVD issue you may want to investigate
TECHBELKIN PLEASE RATE ME.
Nov 03, 2010 | LG (GDR8164B) Internal DVD Drive
Error Code 39 for NG3046P HKW136D SCSI CdRom Device. "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
goto my computer and right click, enter properties and find deice manager click on the (+) sign on dvd/cd rom drives, right click on update driver, use the internet once option and see if it finds an updated driver, if this dosent work reply to this post, good luck.
Aug 12, 2010 | Dell Inspiron 1525 Laptop
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Feb 24, 2010 | Compaq Presario V4000 Notebook
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
DVD/RW IS NOT WORKING CODE 39
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
7) Reboot
your computer
If you found this helpful , please rate my solution below :D
Kind Regards
1234s282
Jul 03, 2009 | Acer Computers & Internet
DVD/CD-ROM DRIVES driver may be corrupted or missing. (Code 39)
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Oct 12, 2008 | Computers & Internet
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Sep 18, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
