Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My steam mop whistled and scared me so I unplugged it. Did I prime it to many times?
As I primed my steam mop a few times and started to move it forward the thing just started whistling at me. I unplugged it and I dont know If I did something wrong? Will it be okay to plug it back in and use it?
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
evbob
  • 8 Answers
SOURCE: shark steam mop
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
Posted on Jun 13, 2009
heatman101
  • 43501 Answers
SOURCE: My shark steam mop will not start steaming. Are
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
f
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: My steam mop all of a sudden stop steaming. The
heatman101
jr
heatman101
  • 43501 Answers
SOURCE: shark steam mop does not create steam. 7 mos old
heatman101
a
Posted on Sep 26, 2010
MY LIBMAN SPRAY MOP WON'T SPRAY AND ITS BRAND NEW. i FILLED THE CUP UP AND PRIMED THE HANDLE AND STILL NOTHING.
Did you ever get a solution? I just bought it today, and am having the same problem. I also sent an email to Libman.
Oct 11, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop - Model S3501 does not produce steam. I checked the water after 10 minutes. It was completely cold. I primed the pump several times as suggested in the user instructions
heatman101
May 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not syeam grey pruple shark steam mop
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mop heats up but won't produce steam. It is only a few months old and used probably 3 times.
heatman101
jkl
Aug 26, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I just filled and started using my steam mop. There was a lot of steam initially, but the mop quickly lost steam and heat within a few minutes of using it. Any ideas?
The water you are using is not able to make steam easily...
heatman101
Apr 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped working during use
heatman101
ii
Feb 23, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Lights on but no steam and getting hot
In order to produce steam, you have to "pump" the steamer. After it heats up, pump it while moving it back and forth on the floor while mopping - it takes a few strokes to get the steam really rolling. I love mine - ;)
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
169 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Chris Hall
Chris Hall
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
