Question about Garden
B & D PW1500 does not start its motor
I acquired the above power-jet cleaner about 2 years ago. It has only been used 4 or 5 times. The motor does not engage when the switch is pressed. (with power on and water on). Initially there was a long delay before the motor came on then the motor stayed on after the trigger was released..
  • boertjie Mar 25, 2009
    Thank you Mr Fixit. I apologise if I did not express my thanks for the trouble you went to. As I live in South Africa, your help-line was not appropriate. I have however managed to sort the problem out with B and D in Cape Town.
InMrFixIt
  • 121 Answers
SOURCE: My 3.99 Karcher pressure cleaner
Hi! robcarroll
Did you purge the air from the pump before starting the motor.
InMrFixIt
Posted on Aug 28, 2008
david04928
  • 102 Answers
SOURCE: the motor is pulsing on and off without the trigger being pressed
It is probably sucking air on one of the connections or around one of the fittings at the regulator. You can also turn the pressure up allittle on the regulator, that might stop it also. Make sure the clamps on the hoses going to the regulator is tite. Also it could be that the regulator is just bypassing water and if it has air in it it will pulsate.
Posted on Mar 15, 2009
  • 174 Answers
SOURCE: Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Posted on Jul 15, 2009
  • 92 Answers
SOURCE: Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
Posted on Jul 22, 2009
  • 174 Answers
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
I have a black and Decker pressure cleaner pw1500. Oil needs replacing in the motor pump. How much oil needs to be replaced and what type of oil?
What makes you think the oil needs replacing. These pumps typically are sealed and have no servicing requirements. You one uses a 3 piston wobble pump which I suspect will have a grease packed bearing in it. (I haven't checked your one, but this is common in these pumps)
May 20, 2016 | Garden
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
I have a 5 burner propane grill & a full tank & a good connection. I'm not getting much heat on the grill which is 4-5 years ago. Do I need to give it a good cleaning as I have never cleaned the...
You can buy a jet cleaner. You need to remove the jet. it screws into the jet cleaner and attach it to your cylinder. Open the cylinder and it blows out the jet backwards. Works a treat. I had one years ago and never had a problem.
Mar 02, 2010 | Barbeques Galore 38-inch Grand Turbo...
Jet AFS-1000B Air Cleaner shuts down after running a short time.
HI
I know this stinks but if the ents to the motor are clean you need your motor rebuilt. There are probably many people in your area who can do this look in yellow pages for electric motor rebuilding, alternator, starter
Dec 02, 2009 | Jet Equipment & Tools 577101 6 1/2 Hp 1...
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Engine sputters while using power equipment
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 22, 2009 | Dewalt Electrical Supplies
Totr model #20479 GTS 5 motor, when you push prime
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
My mcculloch Macpower pac 800E generator won't start. It had been stored for a long time.
The carb is dirty (varnished) from gas sitting in it. You will need to drain the carb and use carb cleaner to remove the old varnish left in it.
Jun 07, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Garden Logo
710 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
