Question about Water Heaters
How many kilowatts should a hot water tank pull or use when heating up?
  • lowrysaa
    lowrysaa Feb 21, 2012
    Before the hot water tank started heating up I was using 2.78kws, when the tank started heating up it jumped to 12.4 kws. Is this normal?
  • 3 Answers
Some heaters have two 4500 heating elements thats 9000 watts or 9kw,s which would need 240 volts at 30 amps.breaker.
Posted on Feb 21, 2012
3 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: gas hot water tank. burner lights,water doesn't
gas regulator gone bad
Posted on Jan 16, 2010
SOURCE: got storage heating and hot water tank .lights on
1) You report that your tank-type electric water heater has lights on the controller.
Please look at label on side of tank to get brand and type of water heater.
Add a comment with all information you have, including description of product.
This will let expert possibly find a manual, and read manual alongside you to assist as you fix water heater yourself.
Keep in mind that expert cannot see your water heater, and that many things cause water heaters to malfunction, and that troubleshoot section of product manual is good place to start.
2) Search manufacturer's website for product manual so you can fix water heater yourself.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) If you have electric water heater and don't want to add a comment with identifying information, then look at following page for do-it-yourself troubleshooting:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) If you have energy smart water heater, you can access information and manual at following link, and possibly fix water heater yourself:
Product manual link shows on page, and gives phone number.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
5) If you do not have tools or know-how to fix water heater yourself, then call a plumber.
Plumbers are expert at fixing water heaters.
6) Post question of professional water heater forum, to double check anything a plumber, friend, or fixya expert says:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 15, 2011
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Water heater supplies about a pint of hot water than turns cold?? what is th eproblem
Hello Rsjohnson164,
I understand that you are having a problem with your hot-water tank not producing any amount of hot-water. I would suggest that you turn off the cold water supply to your hot water tank and drain the tank and see how much water comes out of it.
Flush the tank:
1. Turn off the cold water supply
2. Hook a water hose to the boiler valve (spicket on the bottom of the tank) and turn on the valve
3. Turn on the cold water inlet line and let it run for about 15 minutes or until you get good pressure coming out.
Check the Elements:
1. Turn off the power to the hot-water tank
2. Remove the service panels
3. Remove one wire from the element and use a multi-meter to check continuity
4. If no continuity replace one or both elements
If you do all of this and still have a problem repost to this thread and we will check your thermostats to make sure they are working properly.
Thank you for choosing FIxYa.com
Justin
Apr 21, 2011 | RELIANCE ELECTRIC WATER HEATER
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
I have a rheem hot water tank when you turn on the hot water it comes out nice an hot but not even 30 secounds after that the water cools off and it stays as just warm water. I hear the gas kick in to heat...
Could be your thermostat but it might be your inlet dip tube. Your water heater has a plastic pipe that carries the cold water to the bottom of the tank. When you open your tap, it takes the hot water from the top of the tank, the cold goes to the bottem and gets heated. If this tube breaks, or comes loose, it will short circuit the cycle. The tank is hot but as soon as you start using water, cold water comes in at the top and mixes with your hot water, giving you just warm water. If you have room above your tank, you can remove the union on the cold side , screw out the pipe nipple, and look inside and see if there is a tube. If not you can buy one from home depot or lowes for just a few dollars. Also a water heater should be partially drained annually to remove any solids from the bottom, which will allow better heat transfer.If you find bits of plastic when you do, then you know where your dip tube went. Also if you've had a hot water faucet stop up and it looked like plastic there it is.
Jun 21, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
Central heating circulating pump
The vent pipe should be in front of the pump so that the pump pushes towards the vent pipe NOT sucks from it. I hope this vent pipe is part of the heating system and not of the hot water
Pumps like to push not pull and therefore it is better if the pump is located further down - say at the bottom of the cylinder or lower.
With an indirect cylinder, the hot water & heating are separate circuits and are not and must not be interconnected. You will need a separate pump for the hot water which should be taken from the hot pipe coming out of the cylinder. You may get vacuation in the cylinder - then you will need an Essex or similar valve to replace the hot water outlet connection
By the way - The pressure at any hot tap is directly related to the height difference between the tap and the header tank in the loft [thus a shower downstairs feels stronger than one upstairs]
rod_davies@hotmail.com
Sep 03, 2009 | Grundfos RCP-96 Recirculation Pump for...
Water heater heats but not to same temperature
Try shutting off the gas, shut off the water, and drain the tank to remove any sediment that may interfere with heat transfer from the burner. If that doesn't do it, check the dip tube to make sure it is still intact. The dip tube directs incoming cold water to the bottom of the tank and the hot water is tapped from the top of the tank. If neither of those turn out to be the problem, check the thermo-couple. Since a gas water heater typically survives about 6-9 years, you may be better off just replacing it.
Mar 16, 2009 | Honeywell Water Heaters
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Whirlpool temp control on electric water tank
Most electric water heaters have 2 heaters - an upper and a lower, each with it's own thermostat. These are readily accessible by removing the screw covers on the side of the tank. Careful - the thermostats have 240VAC on the terminal screws (unless you have a small 120VAC heater) if the circuit breaker or fuses feeding the heater are still on - turn them off before proceeding. After removing the two screw covers and pulling back the insulation you will see temperature (screw) adjustments for the upper and lower thermostats, with a temperature indicating pointer attached to each screw. Set both thermostats to 125 degrees or so. Push the insulation back in place, replace the covers and turn the circuit breaker back on that feeds the water heater. You should have warm water within 15 minutes and hot water within a hour or so.
If the water still does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 16, 2008 | Water Water Heaters
Water Heaters Logo
46 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
