I need a wiring diagram for Technics Stereo Systems
    Guru:
  • 513 Answers
Speaker wiring, input wiring, adapter wiring, HDMI, RGB, Video or internal wiring? Do you have a model as many units wire up in different ways...
Posted on Feb 22, 2012
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
My technics sh-eh780 stereo seems to work but the sound is very dull in sound
Unless there's an issue with internal components of the amplifier or speakers, a common cause of this is reversed speaker polarity.
The wires between the + and - terminals of the speakers MUST connect to the same + and - terminals on the back of the stereo amplifier. The speaker wires that came with the stereo are color coded to help prevent mis-wiring. If you did not pay attention to this or used different wires for any reason, you need to ensure that the wires between the each of the speaker's 4 terminals connect to the correct group and + / - terminals on the amp.
See page 6 of the manual here: https://support.panasonic.co.nz/docstore/SC-EH780%20Operating%20Instructions.pdf
Make sure that the surround and center speakers are connected correctly, too.
Apr 06, 2014 | Technics SC-EH780 CD Shelf System
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
I need a wiring diagram for 05 dodge durango sound and ves systems.
  • 2005 Dodge Durango Car Radio Stereo Audio Wiring Diagram
  1. Car Radio Constant 12v+ Wire: Gray/Red
  2. Car Radio Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
  3. Car Radio Ground Wire: Black
  4. Car Radio Illumination Wire: Black/Yellow
  5. Car Stereo Dimmer Wire: Orange
  6. Car Stereo Antenna Trigger: N/A
  7. Car Stereo Amp Trigger Wire: N/A
  8. Car Stereo Amplifier Location: N/A
  9. Car Audio Front Speakers Size: N/A
  10. Car Audio Front Speakers Location: N/A
  11. Left Front Speaker Positive Wire (+): Dark Green
  12. Left Front Speaker Negative Wire (-): Brown/Red
  13. Right Front Speaker Positive Wire (+): Brown/Yellow
  14. Right Front Speaker Negative Wire (-): Brown/Light Blue
  15. Car Audio Rear Speakers Size: N/A
  16. Car Audio Rear Speakers Location: N/A
  17. Left Rear Speaker Positive Wire (+): White
  18. Left Rear Speaker Negative Wire (-): Dark Blue/Red
  19. Right Rear Speaker Positive Wire (+): Brown/White
  20. Right Rear Speaker Negative Wire (-): Brown/Orange
regards, Tony
May 12, 2011 | Dodge Durango Cars & Trucks
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
My technics stereo is not reading any cds at all, can this be fixed??
Hi
yes it can be fixed
maybe there is dust on the laser lens
if not the laser unit need to be replaced
if you want to fix let me know
ecrdn@yahoo.com
Jack
Oct 15, 2010 | Technics SC-DV290 System
A and B channels both have left speakers out.
Use a multitester to check the amps then you can find which amp it is.Under the cover youll see two boards on a aluinum plate.
Oct 26, 2009 | Technics SA-EX140 Receiver
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
Technics hi fi
The audio amplifier IC damaged
May 09, 2009 | Technics SC-DV290 System
176 people viewed this question
 Grubhead
Grubhead
