Question about Kodak Office Equipment & Supplies
Kodak Slide Projector not moving carousel
I have a Kodak Ektragraphic AF-2. and it does not turn the carousel forward or reverse. I can see the coil trying to move the lever but it does not make its full its rotation. Is this an issue with a belt, an adjustment or is it a weak coil?
    President:
  • Kodak Master
  • 412 Answers
Chances are that the LINK that connects the cycle solenoid plunger to the cycle lever is broken. This happens a lot on this generation of projectors. You can purchase the parts from: www.micro-tools.com, as Kodak no longer stocks parts. micro-tools should be able to provide installation instructions! Good Luck!
Posted on Feb 24, 2012
  • 412 Answers
SOURCE: Kodak Projector 760H. Carousel won't
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
Posted on Nov 03, 2010
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
The select bar on the projector is not working.
The Carousel 600 Projector is at least 45 years old!! Great to hear it still turns on!!
Because the 600 has no forward or reverse buttons, forward is accomplished by "tickling" (very lightly push) the Select bar. If you can cycle it forward and no Select, then you need to adjust the cycle solenoid to find the balance between forward and select. If you have NO forward, then chances are either the cycle solenoid is WAY out of adjustment, or the LINK between the CYCLE SOLENOID PLUNGER and the CYCLE LEVER is broken. You should still be able to order the LINK from: www.micro-tools.com
Good Luck !! Jim
May 19, 2013 | Kodak Carousel 600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
On my kadak 4400 I placed a slide tray with 35mm slides in. After turning the power on I attempted to advance the first slide. Nothing happened with the slide. I turned it off reset the tray and tried. ...
Try turning your projector on without a slide tray. Cycle it 2 or 3 cycles in reverse. Place the tray back on the projector and cycle forward. By cycling it a few times in reverse, it re-sets the cycling mechanism.
May 08, 2012 | Kodak Carousel 4400 Slide Projector
I bought a used kodak 650 carousel slide projector and i can't get the slide tray to load. Is it because it came with a 140 slide tray instead of an 80 slide tray?
Aug 10, 2010 | Office Equipment & Supplies
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Kodak ektagraphic AF 1 reverse does not work - anything I can do?
If there are no broken components of the slide change mechanism and it is only an adjustment problem, do the following:
1. Remove the bottom cover
2. At the front of the projector (near the elevation wheel) you will find (2) 1/4" head screws going through black rubber grommets. Loosen the screw slightly.
3. Next to the screws you will see a cutout in 2 pieces of metal that when looked at together, resemble a diamond shape.
4. With the projector on in FAN mode only (NO LAMP!), simultaneously press the reverse button on the side of the projector and with a flat-blade screwdriver inserted into the diamond-shaped slot, twist gently to move the plate the 2 screws go through up or down until you get cycling in reverse. If you go too far you will get buzzing, which will indicate that the solenoid plunger is bottomed out in the solenoid coil. Once you get acceptable reverse cycle, tighten the 2 screws gently and turn the projector right-side up. Verify the correct action in both forward & reverse cycle. Adjust further if necessary. If OK, tighten the 2 screws and re-install the bottom cover. You're done!
Apr 24, 2010 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
Need to make it advance automatically
Sure! Not only did Kodak sell an external automatic timer that plugs into the remote socket, a number of other companies had them as well. If you can't find one searching online for "Kodak slide projector plug-in timer", try: www.micro-tools.com Good Luck !
May 12, 2009 | Kodak Carousel 4600 Slide Projector
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
1,156 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
