Question about Gateway Computers & Internet
Error code 39 - Gateway Computers & Internet
  • Gateway Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Posted on Apr 11, 2012
I have fz1 2008 and engine error code 39 and 34 how i fix it? Any help please jeff_thy@yahoo.com
This link has a table of FZ1 error codes: Thread ECU Error Codes Table
Code 34 means Faulty Ignition - "Fuel is cut off to the cylinder in which the error was detected"
I wasn't able to find the code for 39.
May 17, 2014 | 2008 Yamaha FZ1
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
Error code f5
There is no error code F5. Could you mean 05? That is a flash error
Feb 12, 2013 | Canon Cameras
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
What does this error mean "Error Code texture
If you have a flashed xbox then sometime they wont load the maps or textures correct. You may need to re-flash your xbox to original firmware if you want to finish the game!
May 06, 2011 | Microsoft Xbox 360 Console
Computers & Internet Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
