Question about HP LaserJet P2015dn Printer
HP Laserjet 2015dn will not print
Error message that comes up is :
Function address 0x352beec3 caused a protection fault. (exception code 0xc0000005).
Some or all property page(s) may not be displayed.
When I'm trying to print, first the software says I have to install the printer.
We have re-installed the latest printer driver.
Please can anyone help!
Thank you
  • 39 Answers
You didn't say what type of printer connection you have (Parallel Port, USB, etc) and this may not help any but I do know that HP Printers are VERY finicky about not pluging in your USB cable until told to do so.
Also, did you uninstall the printer software prior to doing the reinstallation? That can sometimes make a huge difference also.
Posted on Oct 29, 2008
Tip
HP Deskjet F4200 Series All-in-One Printers Protection Fault Problem
A lot of HP Deskjet F4200 Series All-in-One printer users complain about the installation problem experienced with this product, especially those using the Windows XP operating system. The driver installs perfectly; it performs the alignment and prints the test page. But as soon as you print a document, photo, or anything from the computer, the printer fails and says "The program has encountered a problem and needs to close". When you go to the printer properties, you'll get a message: Function address 0x500a0490 caused a protection fault. (Exception code 0xc0000005) Some or all property page(s) may not be displayed.
The problem can be resolved by completely uninstalling the driver and installing it again. When the installation is complete, click the START button on the lower left corner of your screen then on the right pane, click 'Printers and Faxes'.
Under the printer tasks, click 'Add a printer' then click Next on the Add Printer Wizard dialog box. Select 'Local printer attached to this computer' and uncheck 'Automatically detect and install my Plug and Play printer' then click Next. Click 'Use the following port' and select LPT1: (Recommended printer port) then click Next.
Select HP under the Manufacturer list and under the Printer list, select hp deskjet 990c then click Next. Select 'Keep existing driver (recommended)'; click Next, name your printer, select Yes to set your printer as the default printer then click Next. Select Yes to print a test page, click Next then Finish to complete the setup. Click OK when a dialog box appears.
Go back to the 'Printer and Faxes' folder and right-click on the name of your printer. Select Properties and click Ports/Connections then check 'USB...Virtual printer for.....hp deskjet 990c'. Click Apply then OK and you should now be able to use your HP Deskjet F4200 Series All-in-One printer.
on Apr 11, 2010 | HP DeskJet F4280 All In One Printer InkJet
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Cant change printing preferences.
please follow the instructions given in the following document. Click here to visit the instruction page.
May 21, 2009 | HP Officejet Pro L7680 All-In-One Printer
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
My printer is switched on but it wont print,what came up was FUNCTION ADDRESS 0x5f446538 exception code 0xc0000005,please help thanking you.shirleyxxxxxxxxxxxxx
This is a memory error...
If your getting this "FUNCTION..." error on the computer screen this is a problem with the print queue, your printing software, or the print driver; not an issue with the printer itself. You will need to uninstall and reinstall the software and driver and if printing USB, remember to change which USB port you use before reinstalling the printer.
Jul 28, 2008 | Office Equipment & Supplies
Printer problem
Remove your printer from the available printers by deleting it. Shut down. Restart and reinstall it. Make sure your cables are connected at the time the manufacturer tells you to.
Dec 21, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet P2015dn Printer Logo
415 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
