Question about Bosch Washing Machines
The tumble dryer does not dry The heater element warms up The fan motor is turning but no heat gets into the drum. Bosch Classixx wash and dry
  • 1 more comment
  • richardk33 Oct 27, 2008
    No the element gets very hot and stays on .
    I removed the motor and found a lot of debree build up which i cleared but it still does not push out any heat.
    This is a wash/dryer so it condenses it out the waste which it is trying to do ,
    The motor is deffenitly turning as is the drum.
  • Anonymous Mar 19, 2014
    the drum doesn't turn at all
Is there air blowing out of the exahust? are you sure the fan is turning? is the drum turning? i suspect the exahust system
Posted on Oct 27, 2008
  • 67 Answers
Does the element heat up then turn right back off after a few seconds? if so, there is 2 sensors that control the heat element, one is in the duct right after the fan. when this sensor senses too hot, it will shut down the heat element. either your sensor is bad, or the lint is not getting out, causing the heat to build up in the duct.
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Dryer not tumbling heat but no tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Apr 19, 2010 | Bosch Classixx WVF 240S Front Load Washer...
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Timer, or Heating element?
The timer small motor malfunction or open./ remove test the two wires by multi tester the continuity/ no response motor broken./ test also fuse . if ok / sometime if motor pop same time fuse burn.
Jan 05, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch wvt 1260
dry heater is located under an aluminium housing on top of the machine. take it to bits and easy to fit. however, why do you need a heater? if no heat on dry, cause is probably overheat stat operated
Mar 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
336 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
