Question about Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H
Where can i find a repair manual for aquaglass jetted tub
Motor wont come on
Aquaglass whirlpool tub
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Our aquaglass whirlpool tub runs for about 10 minutes then cuts off. It will come back on for just a few minutes then cuts off again.
When a motor is doing this it is overheating. You should replace the motor as soon as you are able to. This could cause more trouble for you soon because the motor is over heating.
US Parts Center
Sep 02, 2013 | Home
How can I find the manufacturers name on jetted tub when i can't get access to the motor?
Normally when you install a jet tub you should have an access panel to get at the motor for repair or replacement,I doubt if the name of the manufacturer would be on the motor,as they are probably made by a different company,I have a Maax jet tub but the motor is made by Balboa...try searching manufacturers for the same style of tub as yours!!
Aug 30, 2013 | Home
Where can i purchase an on/off switch for my aqua glass whirlpool tub
We have all the old Aquaglass switches or the replacement for the ones that are not made anymore. Aquaglass Parts
Contact us at: sales@uspartscenter.com or Toll Free 888-521-6183
Rod
US Parts Center
Jan 15, 2013 | Home
Whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
Feb 14, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
Four inch crack in the bottom of aquaglass tub styren
I would contact Whirlpool directly to even see if it is possible. I tried to repair an acrylic tub one time and it didn't keep because the the constant water on it. If it can be repaired, they will give you the solution and info for a contractor that might be able to do the work if you can't do it yourself.
Mar 17, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Sep 28, 2008 | Home
Kohler 1209-LA-0 Hourglass Whirlpool with Integral Apron, Flange and Left-H Logo
186 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
