Question about Blaupunkt PCA1350 Car Amp
The in/out circut board can it be purchaced and where
What's your question?my PCB have got a problem when I look closer I see a head sink on the board they is an ic that bust so I need that number of the ic but it see like it start with T
Although it may be done, i think replacing the circut board rather than the ic would be the answer to this one. Even if you have the equiptment and the skills it takes to succesfully replace the ic, chances are ,a critical circut malfunction occured damaging you chip. The same result may happen again with the new ic.
I would consider pricing either a circut board or a new display all together.
Jun 06, 2016 | Televison & Video
The fuse in the circut board has blown and its made into the board, I was trying to find out where I can get a new circut board.
<P>Get your model number and go to</P><P><A href="http://www.marcone.com">www.marcone.com</A></P><P>&nbsp;</P><P>If this was helpful please rate me.<BR>Leo Ponder Appliance-Tyler,Texas<BR><A href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</A> </P>
Aug 26, 2010 | Refrigerators
Photocopier fuses hi my name is redha i would to have a definition of fuse in the photocopier in general the location and tha function ASAP Please Thanks
Redha,
Fuses are located on the power supply and some control boards.
In general fuses are used for circut protection when the load exceeds what the circut is capable of handling the fuse will blow to hopefully protect the circut and the board. This is a very broad definition.
Hope this helps
Apr 18, 2010 | Gestetner DSc338 Copier
Bosch SHX46A05UC/30 runs for 4 hours.
The circut board in the biege plastic case under the buttons on the right has what is called a cold solder. In other words the solder melts under operational use. Some are repairable and some are not.
1. UNPLUG DISHWASHER or turn off breaker and test for electricity.
2. Remove screws from door panel.
3. Take pic of position of wires going into plastic box.
4. Remove top section of plastic box with buttons exposing small circut board.
5. Open plastic box exposing large circut board and in the middle of it you will see a black spot where the solder has popped. Resolder and reassemble OR replace old circut board and then reassemble.
A new circut board is about $135
Usually electrical parts are not returnable
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-1.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-2.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-3.jpg
Oct 23, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
Defrost circut wired hot nuetral ,should this be d/c with a transformer
Probably uses a Paragon 8145 timer. Wiring as follows
L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
Compressor to 4 on timer, Klixon to X on timer
May 22, 2009 | Hussmann Commercial Freezer DCCG-8
Rear turn signal bulb on passenger side of 1997 GMC Yukon needs to be replaced, how do I do this.
Open your rear door and on the inside jam where the light is remove the two screws.There either a philips or torx head.Rotate out a little and litely pull the other side tabs out of the notches in the quarter panel side.Once you remove the light you will see a circut board with two more screws.Your bulbs are on the inside of the circut board.If your new bulb doesnot work,you may need to replace the circut board,there known to burn out.Hope this helps.John.
Mar 09, 2009 | 1997 GMC Yukon
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Blaupunkt PCA1350 Car Amp Logo
21 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
