Hi. I have an Advent 7203 laptop. When I plug the power supply/charger inthe led on the power supply/charger goes out. Can you help. I can do the repair myself, I just need to know where to look. Many thanks.
  • martini32 Oct 27, 2008
    Hi. Many thanks. Didn?t think of that one. I will let you know how I get on.
    Brigadier General:
  • 6,966 Answers
Three (3) possibilities:
  • power supply/charger - you need to check the output voltage on two (2) instances; without load (not plugged to the laptop) and when plugged. This would require that the cover of the power supply/charger be removed that measurements can be done on the wire. In some instances, the use of an alligator clip with facilitate. Extreme care as the other half of the power supply/charger is live/connected to the mains;
  • defective battery - try removing the battery and run the laptop with just the power supply/charger;
  • defective electronics - either a shorted reverse protection diode or a filter capacitor (most likely).
This of course would require a bit of familiarity with electronic components & circuitry, use of a DVM and eventually/probably a soldering iron. It also requires knowledge of safe working procedures when repairing live units. Should you be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified profession al.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 27, 2008
    Genius:
  • 1,269 Answers
Did you check if the power supply itself is really working properly? Try to use an multi-meter and test if there's a power output from the power supply/charger. If there isn't, you need to use a different power supply/charger.
    Master:
  • 538 Answers
Ok..start by trying it with no battery..it is possible that it is in deep discharge mode, which can affect the turn on
profile..
report back please, and we will go to next step..based on your report..
  • 19,396 Answers
It is either a faulty AC socket on the laptop or a defective AC charger.
Laptop will not charge. when I plug my laptop in to the power cord no lights come on except for the light on the power supply cord goes dim and blinks. anyways help?? thanks, Krystina
Not knowing the age of your unit I can only say that the charger or the battery may be at fault. It is highly unlikely that it is your laptop. Thanks, Dana
Jan 06, 2010 | Gateway M-6843 Notebook
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Sep 17, 2009 | Advent Netbook
Advent 7203 laptop wont power up
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Computers & Internet
I have a advent 7203 laptop - and doesn't want to power up. Ive removed the battery and pressed the power button and then tried it with just the power lead and then the battery but still nothing - any...
Jun 30, 2009 | Acer Aspire 5315 Notebook
Advent 7203 power problem
try useing the more powerfull charger ie the 19v 4.74 amp insteed of the 19v 3.42 amp
this worked for me
Jul 23, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
