Question about Home
Speakman mixometer shower leak
I have a circa 1929 speakman mixometer shower that allows a slow trickle of cold water out of the shower head when turned off. i have found schematics of a mixometer online, but am unsure of my model number, or if there is much variation among them mechanically. has anyone encountered this problem? is it easily solved by tightening? i would like to be as informed as possible before i put my wrench to the thing, so that i can save this cool old feature of the house. i have no formal training, but am fairly competent at these things, especially if someone points me in the right direction.
    Problem Solver:
  • 19 Answers
If your shower get leaked then you should consult with a professional as he can fix this problem very easily.
Posted on May 03, 2013
  • 1244 Answers
SOURCE: A handle in my shower will not rotate and
you will need to dissasemble the faucet control and remove and replace the stem and seat in the unit its just froze and if you try to keep turning it the stem will eventually break
Posted on Jan 20, 2010
frcs68
  • 1605 Answers
SOURCE: replaced our shower cartridge and the shower head
no they are not the same. the plumbmster parts are hair smaller, and it doen't fit correctly.
go to the following link and see if you can get the right part.
http://www.bradleycorp.com/products/showers/showervalves/
Posted on Mar 05, 2009
  • 152 Answers
SOURCE: Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Posted on Mar 26, 2009
  • 1244 Answers
SOURCE: Water leaks from my cold water and hot water
turn the water off! at the meter and go buy a faucet seat removal tool its L shaped with square heads on each end also buy a faucet valve socket to remove the faucet stems after you take the knobs and unscrew the trim housings once you unscrew the faucets stems there inside the hole deep is 2 brass seats that you need to remove and change put the new seats in and replace the washers on the stems and reassemble
  • 32 Answers
SOURCE: Kohler rite temp with diverter.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
Posted on May 27, 2011
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
How do I determine the model number of Speakman Shower faucet?
Before replacing parts, check the diverter for corrosion that prevents free operation.
Jun 19, 2014 | Speakman Home
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
How to remove restricter from Speakman showerhead s2252
You would destroy the shower head trying to remove the part.
Jan 09, 2012 | Speakman S-2251 Showerhead
Leaking water from head when turned off
It is normal for the water to trickle for a little time while the water drains from the shower head. If this continues you will need to repair the shower faucet
Jun 25, 2010 | Speakman S-2252-2 Anystream 6 Jet Dual...
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
I have a 1928 home with a speakman mixometer, the water constantly leaks from the shower handle, also the cold water faucet leaks when it is turned on only. Thanks for your support
http://www.plumbingspecialties.com/downloads/PPfistertoSpeak.pdf......this website offers several blow up diagrams of the mixometer. More than likely it is the packing and all you have to do is tighten the packing nut. You can do this by removing the handle and tightening the nut below it. You may have to remove the escuteon to gain access but the blow up should help you. If you have any questions just ask.
Thx
Ken
Sep 05, 2009 | Home
Automatic Trickle Questions
o you multitask while you wait for the shower to get hot? Brush your teeth? Make the bed? Maybe even pick out your clothes or iron a collar? Many of us do—and don’t know that while we’re feeding the dog or grabbing that second cup of coffee, two-and-a-half gallons of hot water per minute are funneling down the drain. The automatic trickle reduces the flow of the water as soon as it reaches a comfortable 95 degrees. This way your hot water is no longer running down the drain while you’re away from the shower. The automatic trickle allows your showerhead to warm your shower without wasting hot water and tell you (hear) the when your shower is ready. Evolve is the leading manufacturer of this kind of products.
Aug 27, 2008 | Baldwin Hardware 3755 Estate Collection...
Home Logo
419 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
