Question about GE Dryers
Change belt on ge dryer model dwsr463eg6ww
Dwsr463eg6ww
  • 2335 Answers
SOURCE: ge gas dryer
Check this site for info: http://www.applianceaid.com/gas_dryer.html
Posted on Feb 21, 2008
captaynkyrk
  • 170 Answers
SOURCE: ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Posted on Jul 14, 2008
MNTECH
  • 1543 Answers
SOURCE: I need to change a
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Posted on Jan 21, 2009
hektor1961
  • 70 Answers
SOURCE: How do you change belt on GE dryer model
You have to open the door right where the door closes if you look up you'll see two screws take those out and the top just comes off by lifting it up and then on the inside if your in the front of the dryer the screws are pointing to you so once you got the top look at the front panel but from the inside and at the top you'll see two screws one on left one on right take them out and grab the front panel and just lift it it sits on two little hooks or screws on the bottom i usually lift right and than left or left then right.
You will now have access to slide the new belt around the drum and ready to mount on the motor pulley and idler.
Pull your dryer from the wall and remove the back panel by the vent outlet.
You will see a diagram of how belt mounts over both pulleys, follow instructions and reinstall everything the way it was.
GOOD LUCK!
Posted on Aug 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Posted on Sep 26, 2009
Is it possible for me to see the wiring diagram for GE DWSR463EG6WW?
None hidden on your machine eh?
Behind the lower panel...kick plate..back of machine...bottom floor behind the kick plate?? Just trying to help.
I could have been helpful if you had stated your question.
Good luck anyway.
Oct 15, 2013 | Dryers
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
How come when i changed the belt there is so much play on the new belt im not sure if i have the idler tensioner on right ?
That could be the problem look at how the belt is running thru the tensioner and the shaft of the motor. Then run the belt the opposite way if still the same you might have the wrong belt. Get the model number off the dryer and take new belt back to parts house with model number to make sure its right hope this helps.
Jan 07, 2011 | GE Profile Prodigy DPSR513GA Dryer
Dryer belt replacement
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Change belt
do you have the belt route right, on them models they have a safety switch the idler hits and if it is not activated it wont turn
Jun 24, 2009 | GE DWSR463EGWW Electric Dryer
GE DRYER WON'T TURN ON
when you changed the belt, you had to take it apart and remove the front of the dryer am I correct? If so when you put it back together did you make sure to re-connect the wires that go to the door switch? Those wires are the only ones that you should have disconnected to remove the door along with the front. See if you forgot to re-connect them ok?
Feb 17, 2009 | GE Dryers
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
Jan 21, 2009 | LG DLE2512W Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge dryer
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
