Question about Kodak EasyShare C315 Digital Camera
Wont turn on!!!!!!!!!!!
I have a kodak easyshare C530 and the problem is: it wont turn on, i was using it and suddenly it turned off, i changed the battaries and it still wouldnt turn on, after leavin it half an hour it turned on and i was overjoyed! lol but then, after about 1 min it turned itself off again and now wont turn on at all! any ideas please!?!?!?!?!?1 thank youuu xxx
Re: wont turn on!!!!!!!!!!!
I had the same problem. In the end a " 2100mAh Kodak Rechargeable digital battery pack" solved my problem.
Posted on Oct 22, 2007
0 characters
3 Points
What memory card should i put in a kodak easyshare c530 camera
Kodak easyshare c530 has SD/MMC card expansion slot. So you can use any SD(secure digital) or MMC(multimedia cards) storage devices.
Sample pics below: bourngenius_20.jpgSD bourngenius_21.jpgmmc
Feb 14, 2011 | Kodak EasyShare C315 Digital Camera
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
MY Koday EasyShare C530 not supporting 2GB memory
This is from the Kodak website, bad news:
Question : Can I use a 2 GB Secure Digital (SD) memory card in my KODAK EASYSHARE C-Series Digital Camera? Answer : No, your digital cameras is not compatible with 2 GB SD memory cards; your camera accepts a maximum 1 GB SD card.
Hope this helps.
Feb 06, 2010 | Kodak EasyShare C315 Digital Camera
My batterry door is broken I don't know how to put
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Dec 14, 2009 | Kodak EasyShare C315 Digital Camera
Kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Nov 17, 2009 | Kodak EasyShare C315 Digital Camera
I turn my camera on, the green light blinks then the light turns to red blinking then the camera shuts off. What's wrong? Batteries are fine. Also happening with my Kodak EasyShare C530
are you using the recommended battery the (KAA2HR or Ni-MH). If yes make sure that your charger is working fine.
now if your charger is working fined the second you need to do is to recondition the battery or purchased new KAA2HR battery it means that the chemical content on the said battery is already crystallized., this is also applies to your C530 since their using dame battery
Oct 19, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
My lcd screen is broken
you may be able to get the lcd screen from the parts dept. of Kodak but professional repair is highly encouraged
Nov 22, 2007 | Kodak EasyShare C315 Digital Camera
I have the same problem with my daughters camer, i did find a website with a replacement cover
Oct 10, 2007 | Kodak EasyShare C315 Digital Camera
Kodak EasyShare C315 Digital Camera Logo
1,010 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
